239
Oxygen 1.0.2 Release with Stagefright security patches
  1. vinay.k.21
    Jelly Bean Aug 20, 2015
    vinay.k.21 , Aug 20, 2015 :
    You gotta flash the 1.0.0 first... And then 1.0.1 and so on...
  2. sunil.nepal
    Gingerbread Aug 20, 2015
    sunil.nepal , Aug 20, 2015 :
    I'm still on CM12. Should I go for Oxygen OS? Anyone gracious enough to suggest it to me? :)
  3. Lord Boeffla
    Recognized developer Recognized Developer Aug 20, 2015
    Lord Boeffla , Aug 20, 2015 :
    Stay on cm, is my recommendation.
    Oxygen is by far not as complete as it should be. You would miss many features.
    And worst, Oxygen team is very unresponsive when you try to contact them here. So don't expect a good support level.
    It is a shame CyanogenMod and OnePlus broke up. Sad for us users.
    Andi
    vovavika and gstar1897 like this.
  4. sankerpatel
    Cupcake Aug 20, 2015
    sankerpatel , Aug 20, 2015 :
    CYANOGEN OS AND OXYGEN OS BOTH OS ARE DEFERENT KERNAL OS OXYGEN OS IS OLD KERNAL OS.
    Deffrent both os:
    cyanogen os
    1 Default Messanger app inbuilt
    2 gujarati font supported
    3 top side touch to screen lock
    4 power button press to multypal function (screenshot,recover, etc)
    5 this os is latest kernal use 3.4.67 version
    6 android version 5.0.2
    oxygen os
    1 Default messanger app inbuilt not show
    2 Gujarati Font not supported this os
    3 top side touch not work to screen lock
    4 power button function only two opption (poweroff and restart)
    5 this os is old kernal use 3.4.0 version
    6 android is same both os
    many more opption and function both os to deffrent
  5. prasen1101988
    Froyo Aug 20, 2015
    prasen1101988 , Aug 20, 2015 :
    Every time I am trying to update through twrp, it fails to install. What may be the reason? It is clearly written in the post that no reset is required if you are on oxygen os. I am using oxygen 1.0.0 for last 3 months. Any suggestion/solution from any forum member is highly appreciated.
  6. azeez4901
    Ice Cream Sandwich Aug 20, 2015
    azeez4901 , Aug 20, 2015 :
    Yes i beleive so i did.. sorry. Well want to give a try to SOKP5.1? Its got donby digital sound as is quiet impressive,
    championspike likes this.
  7. azeez4901
    Check the download file.. it might have finished without completing. It should be 680 something if i remember correctly.. Wipe cache and dalvik and then try. any notifications?
  8. prasen1101988
    Froyo Aug 20, 2015
    No notification. Yes, the file size is 685 mb. I have tried everything, but it fails again and again. MD5 also does not match to the update version. Do I have to try it after wiping everything? This is not the best way to install your update I guess as I have so many applications already installed.
    Anyway, thanks for the reply.
  9. thunderthump20
    thunderthump20 , Aug 20, 2015 :
    I moved from CM 12S to Oxygen 1.0.2 after learning that my device was vulnerable to STAGEFRIGHT. I used the STAGEFRIGHT detector app from Lookout mobile security and Zimperium Inc.
    After flahsing the issue is partially fixed as Lookout mobile security suggest that my device is not vulnerable but the Zimperium app doesn't think so!
    Screenshots attached.
    Can somebody help fix this issue?
    Thanks
  10. VivaldiNele
    Donut Aug 20, 2015
  11. VivaldiNele
    Donut Aug 20, 2015
    VivaldiNele , Aug 20, 2015 :
    Maybe we will receive it after the launching of Oneplus 9
  12. championspike
    championspike , Aug 20, 2015 :
    na im good with cwm at the moment.. but thanks though
  13. championspike
  14. scottrc
    Eclair Aug 20, 2015
    scottrc , Aug 20, 2015 :
    This update does not fix the stagefright bug fully, only partially. The next update will fix it fully in 1-2 weeks.
    thunderthump20 likes this.
  15. ankur.601
  16. abo231
  17. scottrc
    Eclair Aug 20, 2015
  18. azeez4901
    what recovery are you using? this is strange though... keep a backup of your curent rom before flashing. does any notification follow the failure? can you explain what it says?
  19. Serbian Overlord
    KitKat Aug 20, 2015
    prasen1101988 likes this.
  20. prestigion
