239
Oxygen 1.0.2 Release with Stagefright security patches
  1. phonehog
    Ice Cream Sandwich Aug 21, 2015
    phonehog , Aug 21, 2015 :
    Ahh Wugfresh is it then. Thanks!
  2. johmss
    Honeycomb Aug 21, 2015
    johmss , Aug 21, 2015 :
    No, it doesn´t. Yoy have to try the fixes reported in other treads
  3. soumendu1010
    Cupcake Aug 21, 2015
  4. alexsixt
    Gingerbread Aug 21, 2015
  5. wmm
    KitKat Aug 21, 2015
    wmm , Aug 21, 2015 :
    This is for the One. You couldn't use this on the 2 even if you had it. (Does that make you feel better? :) )
  6. MiguelH
    MiguelH , Aug 21, 2015 :
    NEWSFLASH
    Oxygen OS development on OPO has reached EOL. You better go buy a new toy now.
  7. wmm
    KitKat Aug 21, 2015
    Source? Latest word I saw was that they were still working on it, although the priority went to fixing bugs found by early 1+2 users, naturally.
  8. Ivangeorge
    Ivangeorge , Aug 21, 2015 :
    If you keen on using oxygenos try replacing the kernel or use an app to disable google play services....quite frankly you don't need google play services for any app to function other than proper working of the google play store......now y replace kernel just for undervolting that can add extra battery time...
  9. Ivangeorge
    No problem... Just heads up if you going to install cm 12.1 anyways you don't need to use the tool...just download zip file and enter recovery mode...personally I like cm12.1 with boeffla kernel gives me anywhere between 3-4 Days on light use and 2 days on medium gaming....do not under volt for high graphic intensive games beyond 25 though....
  10. phonehog
    Thanks for the tip.
    I'm still on CM11.44S. If I flash CM12.1, can I go straight from 11.44S or do I need to do anything flash that 05 incremental in between?
  11. idoia1997
    Donut Aug 22, 2015
    idoia1997 , Aug 22, 2015 :
    when will I get an invite? I'm in tier 4.. I need this phone ASAP :( my old one is driving me crazy #HUAWEI
  12. idoia1997
    Donut Aug 22, 2015
  13. amacnaughtan
    Froyo Aug 22, 2015
    amacnaughtan , Aug 22, 2015 :
    oops. oh yeah. luckily that means I can put it on my One!!!
    Nevertheless, I'm still patiently waiting to get my hands on the 2. :)
  14. Deactivated User
    Aug 22, 2015
  15. jeegar
    Cupcake Aug 22, 2015
    jeegar , Aug 22, 2015 :
    I already have oxygenos on my oneplus one. how do i install this patch. all forums keep pointing me to installing this patch as if I am coming from CM but i already have oxygenos installed so hopefully the process is easy.
    I did download the the Zip file from this thread and opened it in TWRP, which i guess flashed my device and installed it. but when i go to settings and click on "about phone" it shows that I am still on oxygenos 1.0.0 and when i use stagefright app to check vulnerability, it says my phone is not secure. pretty sure i am doing something wrong.
    need help
    Thanks
  16. Ivangeorge
    Ivangeorge , Aug 22, 2015 :
    Can flash straight all the firmware comes along with each update cm12.1 250mb size then on can use cyan delta for incremental update....will have to so some research on 5.1.1 google apps though...will have to flash seperately ....or official cm 5.1.1 is expected month end ...so can just wait and flash that one....
  17. hicken
    Honeycomb Aug 22, 2015
    hicken , Aug 22, 2015 :
    I'm glad to see OnePlus is on top of the Stagefright vulnerability.
  18. iigajiwala
  19. singletonbp
    Donut Aug 22, 2015
  20. naresh3386
    Froyo Aug 22, 2015
    naresh3386 , Aug 22, 2015 :
    Yes, it will be
    Leojames and bnpatel like this.
