239
Oxygen 1.0.2 Release with Stagefright security patches
  1. kkmillennium
    Froyo Aug 24, 2015
  2. singletonbp
    Donut Aug 24, 2015
    singletonbp , Aug 24, 2015 :
    The option to turn on WiFi Hotspot can not be activated with the current version of Oxygen OS 1.0.0 on the OPO.
  3. wmm
    KitKat Aug 24, 2015
    wmm , Aug 24, 2015 :
    Strange; it works for me, running 1.0.2, and I _think_ I used it earlier when I was running 1.0.0 or 1.0.1, I forget which; as I say, I don't use it very often. I do vaguely recall that initially I couldn't turn it on from the Quick Settings panel, but after I had turned it on once from the normal settings dialog (Settings -> Wireless & networks -> More -> Tethering & portable hotspot), the Quick Settings toggle works fine for me now.
  4. Eric morne
    Donut Aug 24, 2015
  5. johmss
    Honeycomb Aug 24, 2015
    johmss , Aug 24, 2015 :
    ok, i have no idea wy, but Oxygen connects to wi-fi, but it doesn't work (no internet). and Whatsapp messages only appear if you push them.
    Hoping that the new update comes soon, in order to flash it again
  6. Flyologist
    Jelly Bean Aug 24, 2015
  7. gsaran88
    gsaran88 , Aug 24, 2015 :
    does anyone received stage fright fix from cyanogen for one plus one?
    Any one flashed Oxygen OS ?
    I want to know about the performance difference.Any advantage/disadvantage, which one is better.
    Whether we still receive bug fixes for OPO from cyanogen??
  8. Mithun C
    Donut Aug 24, 2015
  9. bens87
    Cupcake Aug 24, 2015
    bens87 , Aug 24, 2015 :
    I used the Oxygen recovery. Turn on update OnePlus recovery in developer options. reboot into recovery and select update from sdcard. select the 1.0.2 zip file which you put in the root of your OPO and it will update without losing any data. mine did anyway.
  10. plank88
    Donut Aug 24, 2015
    plank88 , Aug 24, 2015 :
    Finally after many updates i can say i am seeing improvements with my touchscreen issues.
  11. MrOnePlusLTE
    Gingerbread Aug 24, 2015
    MrOnePlusLTE , Aug 24, 2015 :
    Denmark can confirm that the update is available now. I just completed it
  12. abhishek.sharma
  13. McflyNecro
  14. DanielPotoni
  15. nullthegrey
    nullthegrey , Aug 24, 2015 :
    Installed this on my OPO, didn't fix my touchscreen issues, but install went fine nice work.
  16. asbalaji666
    mjgardes likes this.
  17. janhaesen
    Donut Aug 24, 2015
    janhaesen , Aug 24, 2015 :
    Hi Robert, you can put the file in your root directory on your phone and flash it from there without losing any data. I did so myself, as some already state you can also await the OTA which is being pushed. I myself did it through flashing.
  18. Rodav
    Rodav , Aug 24, 2015 :
    you know that most of the larger companies released a patch already ? And the Samsung patches were out weeks ago and they have more phones than Oneplus.
  19. KodyJackson
    Donut Aug 25, 2015
  20. eoneder
    Donut Aug 25, 2015
