239
Oxygen 1.0.2 Release with Stagefright security patches
  1. nanopp
    Donut Aug 27, 2015
    nanopp , Aug 27, 2015 :
    This doesn't work for me, touchscreen freeze persists
  2. sogyals429
    Cupcake Aug 27, 2015
  3. katy.barraud
    katy.barraud , Aug 27, 2015 :
    Any news ?
  4. Fahad23
    Fahad23 , Aug 27, 2015 :
    Hi I hope someone can help me with these questions
    1) does the dual SIM support LTE ? Because I've read that the dual SIM support LTE and 2G
    2) are there more than one version for oneplus two , Like China version and EUR version ?
    3) is there any update coming on they way to fix and enhance the OS from the issues that I've read about ?
    Thnx
  5. cajy7817
    Eclair Aug 28, 2015
    cajy7817 , Aug 28, 2015 :
    Just flashed COS 12.1 on my OPO... Works great.. Really liked the menu.. Hated the true caller though, but that can be taken care of. It is however smoother than Oxygen OS or CM 12s.. Trust me people, instead of waiting for Oxygen OS 2.0 for OPO, go for COS 12.1... I doubt Oxygen OS 2.0 would ever be out like the end of next year... The only reason they had to release the security patch for Stagefright because it was discovered last month... If this vulnerability was not discovered, there would be no update for OPO(In terms of Oxygen OS)
  6. richo262
    Cupcake Aug 28, 2015
    richo262 , Aug 28, 2015 :
    Why does my oneplus one even bother checking for updates at all when the updates are never released OTA? This is stupid and not very convenient, beginning to this OxygenOS is dead on the 1.
    hurrynot likes this.
  7. RickyRicardo
    RickyRicardo , Aug 28, 2015 :
    Are there any major glitches with Oxygen OS?
  8. abhaynite5
    abhaynite5 , Aug 28, 2015 :
    okay thanks
  9. Egon
    Gingerbread Aug 28, 2015
    Egon , Aug 28, 2015 :
    Did you flashed COS 12.1 from OxygenOS?
  10. johmss
    Honeycomb Aug 28, 2015
    johmss , Aug 28, 2015 :
    It's posible. You just have to wipe dalvik, cache, (as any flash normally requires), install the +600MB zip file, wipe cache again and up you go.
  11. wmm
    KitKat Aug 28, 2015
    wmm , Aug 28, 2015 :
    Yes, and it worked just fine.
  12. liamandren
    Gingerbread Aug 29, 2015
    liamandren , Aug 29, 2015 :
    Hey! Alright, then it should be fixed if you do what I did. I had the problems with CM12 first, so then I flashed to Oxygen OS 1.0 and the issues still persisted. I then flashed the so called "touchscreen fix"-version (Oxygen OS 1.0.1, the first zip-file in this thread https://forums.oneplus.net/threads/an-oxygenos-update.317098/ ). I didn't download the ".zip.md5"-file, partly because I don't really know what it does, and also because I thought it didn't matter that much. I did not download the "tool" from XDA developers that they talked about in the linked thread, because it's really quite unnecessary.
    So basically - once I had my device on OxygenOS 1.0, I downloaded the first zip file in the linked thread to my windows 10 computer (works with Windows 7, Windows 8, Windows 10). I LEFT the file unzipped/untouched after the download. I then transferred the file to my OPO using Android File Transfer (a USB-cable). I then booted my phone into the TWRP-recovery mode (I already had TWRP installed since I used that for the switch from CM12 to OxygenOS). I wiped cache and Dalvik, then went on to find the zip-file and flash it! Took maybe 5-10 minutes for the install, and after that was done all the problems were gone!
    Sorry for a slow reply mate!
    nanopp likes this.
  13. Egon
    Egon , Aug 29, 2015 :
    Do you have to wipe system as well? I through you couldn't do a Dirty install...
  14. Egon
  15. morecowbell
    morecowbell , Aug 29, 2015 :
    Having touhscreen issues since updating. Can anybody tell me if these are the same errors (touchscreen) that prexisted or are they different?
  16. pateldharmik14
    Cupcake Aug 29, 2015
    pateldharmik14 , Aug 29, 2015 :
    I need Help with the Shelf, If you can Please tell me how do I change the name of the owner which appears on Shelf without Hard reset.
  17. wmm
    KitKat Aug 29, 2015
    wmm , Aug 29, 2015 :
    I don't know if you have to or not. I did a factory-reset wipe in TWRP just to be on the safe side and haven't had any problems.
    Egon likes this.
  18. Gaurav Kanted
    Froyo Aug 29, 2015
    Gaurav Kanted , Aug 29, 2015 :
    Pls add a search option too for the files menu in the next OTA of Oxygen!
    We definitely need to search between documents with soo much stored.
    #OnePlusTwo #NeverSettle
  19. alexanderchan
    alexanderchan , Aug 29, 2015 :
    Totally confused. I was reading the original post . Helen said that there maybe a additional updates. will 1.0.2 be rolled out via OTA? I am in the US.
  20. johmss
    Honeycomb Aug 29, 2015
    johmss , Aug 29, 2015 :
    No.
    They'll hace yo make (add) a new update, but OTA, das never mentioned.
    Apparently, ir will be next week
