Oxygen 11 update font size and display size problem via OnePlus 7T Pro
  1. #1
  2. Punk_69
    Lollipop Mar 30, 2021
    Punk_69 , Mar 30, 2021 :
    Decrease the font size then, it's under display settings.
    You didn't have to create this thread, you could've explored the settings...
    Martijn.Poot likes this.
  3. ghostofcain
    Marshmallow Mar 30, 2021
    ghostofcain , Mar 30, 2021 :
    Its a google decision, if you read the release thread for the stable build, which I assume you're running?, You will find a solution to your issue.
    Aaron2017 likes this.
  4. rahulmadole94 , via OnePlus 7T Pro , Mar 30, 2021 :
    I know what I want to create and what I don't ... not as small as it should be in the settings like Oxygen 10
  5. rahulmadole94 , via OnePlus 7T Pro , Mar 30, 2021 :
    🤔 What does this mean?
  6. Aaron2017
    KitKat Mar 30, 2021
    Aaron2017 , Mar 30, 2021 :
    What it says, several users provided other users with a solution to your font size question on said thread
    ghostofcain likes this.
  7. ghostofcain
  8. camohan
    Moderator Moderator Mar 30, 2021
    camohan , Mar 30, 2021 :
    Hi there, I know how to fix this.
    Do this
    1. Enable Developers options - go to settings, about phone, tap on build name 7 times, developer options will get activated.
    2. Go back one step, systems, you will see developer option
    3. Search for smallest width and select 441.
    Enjoy.
  9. rahulmadole94 , via OnePlus 7T Pro , Mar 30, 2021 :
    You are genius sir...it works... thank you so much
    ... sorry but can u tell process for same but for app icon size ...I want it also small
  10. camohan
    Hi there, glad that helped.
    For icon - you can long press on blank place on home screen, home screen settings, home screen layout, 2nd button on the left side, icon size, choose smallest. If that small isn't small enough, then the option is to use a different launcher.
  11. rahulmadole94 , via OnePlus 7T Pro , Mar 30, 2021 :
    Ok thanks
    camohan likes this.
  12. Punk_69
    Sirji to the rescue
    camohan likes this.
  13. Craig.Mammalton
    Eclair Apr 22, 2021
    Craig.Mammalton , via OnePlus 7 Pro , Apr 22, 2021 :
    It's not a text size problem, if you used the display setting "small" prior to update, it scaled all aspects of apps to be smaller, now it reflects as what would be "large" in android 10 and changing font size does not fix it. Thanks for the hostility to this individuals thread.
