49
Oxygen 3.0 buglist
Please select bugs in community build version of oxygen os 3.0, if you are facing any.
  1. Heating
    31.3%
  2. Fast Battery Drain
    57.2%
  3. Lagging
    12.7%
  4. Network issues
    14.9%
  5. Wifi issues
    20.5%
  6. Poor audio quality
    46.3%
  7. Loud ringtone
    16.8%
  8. Crashing of apps
    9.7%
  9. Others
    33.5%
Multiple votes are allowed.
  1. MafiaTechTeam
    Jelly Bean Mar 30, 2016
    MafiaTechTeam , Mar 30, 2016 :
    too the one regarding removing security, im pretty sure its standard issue.......
  2. crash_194
    Gingerbread Mar 30, 2016
    crash_194 , Mar 30, 2016 :
    I'm trying to make sure I don't start looking for issues that aren't there you know lol as I can feel myself doing it. As far as a beta release goes this really isn't that bad.
    I'm just using the phone as I normally do and I'm having quite a positive experience so far, apart from the loud as hell volume! Lol
  3. malidan
    Nougat Mar 30, 2016
    malidan , Mar 30, 2016 :
    Yes i can see the end results, if you don't know how wait for an ota.
  4. Rogier123
    Ice Cream Sandwich Mar 30, 2016
    Rogier123 , Mar 30, 2016 :
    6 is not a bug. People should learn to read. Helen posted they would be removed.
    m_kozal likes this.
  5. Amjass12
    Honeycomb Mar 30, 2016
    Amjass12 , Mar 30, 2016 :
    Quite often when unlocking with finger print, it recognised but opens lock screen with keypad to unlock, does not directly unlock.
    This is not after restarting, this is during normal use.
  6. mi6t0
    mi6t0 , Mar 30, 2016 :
    Dialer -> settings -> sounds and vibration wont work.
    No option for setting a ringtone per sim card.
    A delay before showing the home.screen after unlock with nova launcher.
    slight shutter when showing the quick toggles
  7. malidan
    Nougat Mar 30, 2016
  8. majzok
    majzok , Mar 30, 2016 :
    You are right, removed from list.
    Rogier123 likes this.
  9. leddy231
    Eclair Mar 30, 2016
    leddy231 , Mar 30, 2016 :
    Im getting wierd doubble vibrations when pressing any navigation key, feels kinda strange. 100% of the time.
    JariVanBoven likes this.
  10. leddy231
    Eclair Mar 30, 2016
    Go to settings > buttons > on any buttons long press or doubble tap add "search assistant" (i think nexus uses long press on home) and done
    Saif.baig1234 likes this.
  11. javierlimonr
    Cupcake Mar 31, 2016
  12. DeathToGooglePlus
    Honeycomb Mar 31, 2016
    DeathToGooglePlus , Mar 31, 2016 :
    When I press the home button it takes me home but it keeps activating as if im repeatably pressing it. Phone vibrates like crazy. Seems to work with fingerprint to unlock and on screen keys. other than that if I use the physical button it goes crazy! have tried all sorts of reboots, resets and wipes.
  13. MatisyahuSerious
    MatisyahuSerious , Mar 31, 2016 :
    i think you accidentally sent this PM to the thread.
    hchnielsen likes this.
  14. s.prakash742
    s.prakash742 , Mar 31, 2016 :
    Someone plz help me.. After the successful installation my phone is rebooti for hours (still it is rebooting around 6hrs) ....
  15. awesomeX1
    awesomeX1 , Mar 31, 2016 :
    A bug I discovered:
    Settings crash upon opening app permission settings (another person has same issue as me)
  16. xmichael2008x
    Froyo Mar 31, 2016
    xmichael2008x , Mar 31, 2016 :
    Missing Fingerprint section in Security & fingerprints to register fingerprints.
    Attached screenshots.
  17. d1beats
    Jelly Bean Mar 31, 2016
  18. Manas Eapen
    Manas Eapen , Mar 31, 2016 :
    Guys,
    How slow is the WiFi ?
    How bad is the audio output from both the speaker and audio jack ?
    If both of these are bad, it's a deal breaker for me.
  19. Manas Eapen
    Could be on a boot loop.
    Press the power button for 10 seconds to shut it down and restart it.
  20. Echomalinois
    Eclair Mar 31, 2016
    Echomalinois , Mar 31, 2016 :
    Had some strange distortion while playing music via Bluetooth but things hadn't completely settled after the update. I'll check tomorrow on the way to work and see if it's still an issue.
