49
Oxygen 3.0 buglist
Please select bugs in community build version of oxygen os 3.0, if you are facing any.
  1. Heating
    31.3%
  2. Fast Battery Drain
    57.2%
  3. Lagging
    12.7%
  4. Network issues
    14.9%
  5. Wifi issues
    20.5%
  6. Poor audio quality
    46.3%
  7. Loud ringtone
    16.8%
  8. Crashing of apps
    9.7%
  9. Others
    33.5%
Multiple votes are allowed.
  1. Ranjithsmart
    Jelly Bean Mar 31, 2016
    Ranjithsmart , Mar 31, 2016 :
    Please somebody close this thread these only making one plus to go down. If you were having a skill try to solve those bugs. MM UPDATE IS RELEASED AFTER A HEAVY WORK....
  2. Cromartie
    Eclair Mar 31, 2016
    Cromartie , Mar 31, 2016 :
    Are you using nova launcher? Try disable the double tap gesture
    Amjass12 and awesomeX1 like this.
  3. androidfan21
    Gingerbread Mar 31, 2016
    androidfan21 , Mar 31, 2016 :
    Does it wipe data for real? All data?
  4. awesomeX1
    Honeycomb Mar 31, 2016
    awesomeX1 , Mar 31, 2016 :
    If you're completely stock, you wouldn't have to wipe; you could just dirty flash
  5. naaaateeee
    Froyo Mar 31, 2016
    naaaateeee , Mar 31, 2016 :
    Well I found several bad things there in the update. The first issue is very important: sometimes the home button acts like crazy! I launched Deus Ex The Fall and was returning to home screen eventually during the game process. After that, I decided to stop playing and check what's the problem. Then my home button went crazy and started quickly swapping between home screen and launcher settings (where you select between settings, wallpapers and widgets). Sometimes when I tried to press the Recent button, home button worked instead. Also probably because of this, the phone sometimes won't let me unlock it by my finger, it requests the password instead — the second issue I found.
    And there's the third issue which is not connected to the ones I mentioned: in the "configure apps" menu (which is in the settings>apps) the access permissions are impossible to choose, the phone returns back to the "configure apps" menu.
    It would be very good to see more performance and UI improvements, because several small lags are present like scrolling in Google Play Store.
    Well this is probably everything I've got, sorry if my post is hard to understand however I still want to post it because I don't want anyone suffer when their home buttons go crazy:D
    But still, thank OP, I'm still happy having this ROM on my phone :)
  6. lunamartin85
    Cupcake Mar 31, 2016
    lunamartin85 , Mar 31, 2016 :
    Not sure if I can consider this a bug, but camera quality image is not good at all.
    Compared to pictures taken few minutes before the upgrade, new ones look really bad.
    I don't know if I'm the only one who notice this or if it's a common issue
  7. naaaateeee
    Froyo Mar 31, 2016
  8. androidfan21
  9. lilrob1213
    Eclair Mar 31, 2016
    lilrob1213 , Mar 31, 2016 :
    didn't see this yet, the files app attempts to open when clicked on, but flashes back to whereever you just were... doesn't work.
  10. bala
    bala , Mar 31, 2016 :
    Eventhough i have fingerprint set up when i try to unlock it via the fingerprint it goes to enter the pattern screen i could see it reads the fingerprint and it matches but, there is some sort of bug, to get back to working state i have to simply go into the fingerprint in settings panel once and it starts to work again..weird bug have anyone else facing this?
  11. ratneshbhai
  12. Varun_Yadav001
    Varun_Yadav001 , Mar 31, 2016 :
    Audio quality is even better... Ya but music no bass available.
    JariVanBoven likes this.
  13. ratneshbhai
    ratneshbhai , Mar 31, 2016 :
    You need to visit ENT my friend
  14. Varun_Yadav001
    Well...bro Have done audio testing and call testing...Audio for music player is bit slow..
    Nd Call quality is Better :)
  15. acused
    acused , Mar 31, 2016 :
    Worst battery life update. This oxygen app is taking up 15% battery within 30 minutes. I already wiped cache to try to solve the issue. But it didn't help
  16. beingathar
    Froyo Mar 31, 2016
    beingathar , Mar 31, 2016 :
    I can confirm the mentioned bugs.
    The MM is smooth but experiencing bad battery drain. Clean flash!
  17. ratneshbhai
    whatever its not upto the mark
  18. SlimeDude
  19. abhishekgarg294
    Ice Cream Sandwich Mar 31, 2016
  20. Varun_Yadav001
