49
Oxygen 3.0 buglist
Please select bugs in community build version of oxygen os 3.0, if you are facing any.
  1. Heating
    31.3%
  2. Fast Battery Drain
    57.2%
  3. Lagging
    12.7%
  4. Network issues
    14.9%
  5. Wifi issues
    20.5%
  6. Poor audio quality
    46.3%
  7. Loud ringtone
    16.8%
  8. Crashing of apps
    9.7%
  9. Others
    33.5%
Multiple votes are allowed.
  1. SadButTrue
    Ice Cream Sandwich Mar 31, 2016
    SadButTrue , Mar 31, 2016 :
    nope it isn't - google calls it patchlevel april 2nd
  2. senegalas
    senegalas , Mar 31, 2016 :
    Thanks for info. I wont install Oxygen because Im audiophile. @Helen audio is important role in our life please fix audio issues and add support for viper fx since it makes sound a lot better compared to shitty maxxaudio. We want the best audio quality from our headphones!!!
  3. Jitesh Saitawadekar
    KitKat Mar 31, 2016
    deviantartjr likes this.
  4. stefan_ddorf
    Jelly Bean Mar 31, 2016
    stefan_ddorf , Mar 31, 2016 :
    No, a newer one. This one doesn't work if you met Penny on the stairs before :)
  5. Ksreddy9
    Honeycomb Mar 31, 2016
    Ksreddy9 , Mar 31, 2016 :
    mine getting discharging even cable connected and not using the phone
  6. jahowyuduin
    Froyo Mar 31, 2016
    Dharmz98 likes this.
  7. deviantartjr
  8. kryddan
    kryddan , Mar 31, 2016 :
    That helped, Thank you so much :)
    jpswer likes this.
  9. jahowyuduin
    Froyo Mar 31, 2016
    TheKhemist likes this.
  10. HeTalks
    Gingerbread Mar 31, 2016
    HeTalks , Mar 31, 2016 :
    @majzok ... if you wanna add to the op.
    Dialer settings >> Sounds and vibration <- this doesnt work and app gets reloaded. Looks like it did force close which got suppressed.
  11. majzok
    majzok , Mar 31, 2016 :
    Issue confirmed on my device too, added to list.
    HeTalks likes this.
  12. Linuspogo
    Eclair Mar 31, 2016
    Linuspogo , Mar 31, 2016 :
    Anyone else seeing problems with Android Wear? My Moto 360 1st Gen is shown as "connected" in the Android Wear App, but nothing is synced (notifications, music...). It worked for a short time, but then stopped working. I tried wiping the watch and re-pairing, but it didn't help. Probably some Bluetooth problem with the OP2..?
  13. TSluggard69
    TSluggard69 , Mar 31, 2016 :
    Some users get low wifi speeds. It is in the problems close to changelog
  14. TSluggard69
    breeze99999 likes this.
  15. TSluggard69
    Calibrate your battery.
  16. moffe79
    Eclair Mar 31, 2016
    moffe79 , Mar 31, 2016 :
    Works for me fine...
    jpswer likes this.
  17. TSluggard69
    Have you did a clean install?
  18. moffe79
    Eclair Mar 31, 2016
    Nope... Well I cleaned cache. That was the only thing
  19. TSluggard69
    Man make a clean install and then see if the problem happens. It doesnt happen to me.
    Is good to send bug reports only if you have did a clean install, because sometimes dirty flashed create a lot of errors. Even more with a upgrade ll to mm.
  20. moffe79
    Eclair Mar 31, 2016
    Yes, I know...well. Don't seem to have any issues at the moment. Only charging is a bit slow but it works and 1password issue with fingerprint. But that is know by the team that made the app. So most likely it's not something wrong with the SW.
