49
Oxygen 3.0 buglist
Please select bugs in community build version of oxygen os 3.0, if you are facing any.
  1. Heating
    31.3%
  2. Fast Battery Drain
    57.2%
  3. Lagging
    12.7%
  4. Network issues
    14.9%
  5. Wifi issues
    20.5%
  6. Poor audio quality
    46.3%
  7. Loud ringtone
    16.8%
  8. Crashing of apps
    9.7%
  9. Others
    33.5%
Multiple votes are allowed.
  1. abhishekgarg294
    Ice Cream Sandwich Mar 30, 2016
    abhishekgarg294 , Mar 30, 2016 :
    bro my op2 stuck up on oneplus logo what should i do now?
    #61
  2. Jitesh Saitawadekar
    KitKat Mar 30, 2016
    #62
  3. Sr Vincenzo
    Sr Vincenzo , Mar 30, 2016 :
    Yes I read your initial post. However my statement was never intended towards you, so no need for the insults. My point is that people could be dirty flashing, and say they found a bug when it could've been avoided with a clean flash.
    #63
    krak and malidan like this.
  4. dinjesk
    KitKat Mar 30, 2016
    #64
  5. majzok
    Gingerbread Mar 30, 2016
    majzok , Mar 30, 2016 :
    Then i apologise to you, good sir - no insult intended. But to be trough: this is beta and OnePlus ask to dirty flash it and then test it - so I think what OP want's to test waters for OTA, what is (more or less) just dirty flash.
    #65
    Saif.baig1234 likes this.
  6. majzok
    You should boot into fastboot, flash newest TWRP, then reboot to recovery and do a wipe (data, no storage) and then flash downloaded zip, you can wipe cache after that and reboot. Remember that first boot can take a while (but should be under 5min).
    #66
  7. malidan
    Nougat Mar 30, 2016
    malidan , Mar 30, 2016 :
    Ok
    Who mentioned OTA, where did I mention OTA.
    Did I mention OTA. NO. So what are you rambling on about.
    Does the turn headless chicken mean anything to you? Because that how your behaving now. Bringing up random stuff in an attempt to justify yourself.
    You used the words FULL ROM why would you need to dirty flash a full ROM, I take it that information was incorrect.
    #67
  8. broder_salsa
    Froyo Mar 30, 2016
    broder_salsa , Mar 30, 2016 :
    I am stuck in bootloop, but I only used the stock recovery. My device isn't rooted. Will you help me, please? I think it's broken.
    #68
  9. abhishekgarg294
    while installing it say md5 verification failed
    skiping md5 verification
    zip signature failed
    and rom could not able to install
    #69
  10. Democrito
    Honeycomb Mar 30, 2016
    Democrito , Mar 30, 2016 :
    Bug? I cant find the new wallpapers...
    Bug I cant set rapid function for lockscreen only and unlocked device...
    #70
  11. majzok
    Oh man... This is your's, right?
    https://forums.oneplus.net/threads/oxygen-3-0-buglist.439077/#post-14677410
    So as you can see, you started this whole conversation, when you asked me
    after i told one guy
    Maaaan
    #71
    flwr likes this.
  12. majzok
    Cuz you have old twrp. (or try downloading file again)
    #72
  13. maikeven
    Donut Mar 30, 2016
    maikeven , Mar 30, 2016 :
    No problems here, this is with the beta.
    #73
  14. majzok
    Try holding power button for 10 seconds. That should turn your phone off, then boot to recovery (power btn + volume down if i remember correctly).
    #74
  15. abhishekgarg294
    now i install op2 stock recovery again and flash oxygen 3.0 is i done right?
    #75
  16. broder_salsa
    Froyo Mar 30, 2016
    Okay, any advice for what i should do afterwards? Thank you so much!
    #76
  17. majzok
    Did you tryied to flash anything before bootloop?
    #77
  18. broder_salsa
    Froyo Mar 30, 2016
    I did flash the Oxygen 3.0 zip, but that's all.
    #78
  19. stephenboyo
    KitKat Mar 30, 2016
    stephenboyo , Mar 30, 2016 :
    Arent you downloading this on your OPT, would be good to hear your views...
    #79
  20. majzok
    Do data wipe, then if you can in stock recovery do wipe cache. If that wont help, check if your zip file is 1,11 GB (baits: 1 194 776 016,00) in size. If it isn't it means that download failed and you have to redownload file and place it in your phone and flash again.
    #80
