49
Oxygen 3.0 buglist
Please select bugs in community build version of oxygen os 3.0, if you are facing any.
  1. Heating
    31.3%
  2. Fast Battery Drain
    57.2%
  3. Lagging
    12.7%
  4. Network issues
    14.9%
  5. Wifi issues
    20.5%
  6. Poor audio quality
    46.3%
  7. Loud ringtone
    16.8%
  8. Crashing of apps
    9.7%
  9. Others
    33.5%
Multiple votes are allowed.
  1. Lazdaa
    Eclair Apr 5, 2016
    Lazdaa , Apr 5, 2016 :
    Anyone else having random reboots and sometimes small boot loops?
  2. Kreg
    Cupcake Apr 5, 2016
    Kreg , Apr 5, 2016 :
    Dears,
    As I already said, Thank you for the work done so far. Improvements where at the Rendez-vous.
    But, like lot of us, I got some problems with :
    1. Heating
      131 vote(s)
      25.0%
    2. *
      Fast Battery Drain
      258 vote(s)
      49.3%
    3. *
      Poor audio quality
      244 vote(s)
      46.7%
    When could we expect the new Update and in the same time the resolution of these bugs?
    Thanks beforehand for your answer.
    Regards,
    Grégoire
  3. zehar.salem
    Honeycomb Apr 5, 2016
    zehar.salem , Apr 5, 2016 :
    Hello again,
    Another thing I am facing is a bootloop when I try to boot into recovery.
    PS\ my device is encrypted.
    No solution found, had to to format the device and start again :p
    It does not bother me coz everything is backed up.
  4. zehar.salem
    Try to put the Inbox app in the white list.
    Settings > battery > battery optimization > all apps > select Inbox and select do not optimize.
  5. Rudra123456
    Gingerbread Apr 5, 2016
    bharath740 and mindhunter991 like this.
  6. mindhunter991
    mindhunter991 , Apr 5, 2016 :
    i did a clean install only...not the dirty one
    i'm unable to get into recovery mode
    I also noticed a new icon...a crossed bell in which neither the phone rings nor vibrates even if the alert slider is in 'all notiifications' mode
  7. zehar.salem
    Settings > Battery > Battery optimization > all apps > select the Inbox app and "do not optimize"
    This should solve your issue
  8. zehar.salem
    You knew all that stuff before buying your device. If you didn't blame your self for not doing a research prior buying this phone.
    My advice sell your OP2 (if you have one) and buy something that suit your needs. Because I am pretty happy with what I have more happy than Nexus 5x users ;)
  9. Rudra123456
    bharath740 likes this.
  10. koelkastfilosoof
    Cupcake Apr 5, 2016
    koelkastfilosoof , Apr 5, 2016 :
    Hi,
    I'm facing the following issue: If I open the recent apps menu, the 'close all' button is underneath the list. In OOS2 it was on top, I really would like to have it back there so I don't have to scroll all the way down!
    Thanks!
    EDIT: Added screenshot: http://imgur.com/xuV2s1y
  11. Rowman
    Rowman , Apr 5, 2016 :
    I have the heavy battery drain too
    Cache cleared, multiple charging cycles,.. Nothing helped
    Even rebooting doesnz solve the problem
    Most of the time I get this after 2-3h after charging
    At the moment I use the battery saving mode when I feel that my phone gets hotter
    This stops it reliably
  12. Rowman
  13. sfksuperman
    sfksuperman , Apr 5, 2016 :
    bro, before buying i hoped that when oneplus will launch its earphone and other accessories, it would range in small amoung, not in thrice the thousands :p
    zehar.salem likes this.
  14. sfksuperman
    what i mean to say is that there is an option to resize the window and mpve freely around the screen but t would require a xposed module.But i think it should be in DEVELOPER option too.
  15. zehar.salem
    I got you point!
    Althought I am using BOSE QC 20 headphones. I am OK with the quality, only listning to podcasts and radio streams no music.
    The quality is fine here. BTW I am not an audiophile :p
  16. sfksuperman
  17. grcool
    Cupcake Apr 5, 2016
    grcool , Apr 5, 2016 :
    It's looks like - the screen and image quality is good, i'm using smartphone only as flashlight.
  18. zehar.salem
    I happy you found a use for it ;)
  19. alfieeee
    Donut Apr 5, 2016
    alfieeee , Apr 5, 2016 :
    Does YouTube videos pause every half minute or minute for anyone else, that is so annoying...
  20. glasshouse82
