49
Oxygen 3.0 buglist
Please select bugs in community build version of oxygen os 3.0, if you are facing any.
  1. Heating
    31.3%
  2. Fast Battery Drain
    57.2%
  3. Lagging
    12.7%
  4. Network issues
    14.9%
  5. Wifi issues
    20.5%
  6. Poor audio quality
    46.3%
  7. Loud ringtone
    16.8%
  8. Crashing of apps
    9.7%
  9. Others
    33.5%
Multiple votes are allowed.
  1. Moin2200
    KitKat Mar 30, 2016
    Moin2200 , Mar 30, 2016 :
    Do I need to have bootloader unlocked to flash this on stock?
    #81
  2. Varun_Yadav001
    Honeycomb Mar 30, 2016
    #82
  3. abhishekgarg294
    Ice Cream Sandwich Mar 30, 2016
    #83
  4. majzok
    Gingerbread Mar 30, 2016
    majzok , Mar 30, 2016 :
    Its not VPN issue, it is APN issue.
    #84
  5. ThePixelCutter
    #85
  6. majzok
    No, just flash it in stock recovery.
    #86
  7. Moin2200
    KitKat Mar 30, 2016
    #87
  8. kishen prashanth
    Eclair Mar 30, 2016
    kishen prashanth , Mar 30, 2016 :
    Hey friends,
    Been using O²OS 3.0 past one hour...animations,finger print scanner,app launch everything is silky smooth....i wud say its a 50% improvement over previous version....but tfew things are annoying like the dark theme doesnt look much dark in the app drawer...little improvementsneeded....
    Bugs :
    1) audio via headphones are bad
    2) wifi speeds are too slow as expected
    3) music player in the notificationdrawer has blue color instead of black:/
    4) battery is draining a bit faster..but have to test it for a week!
    5) the app drawer doesnt show recent apps
    6) screen locking and touch sounds are too low which has not been addressed frm the beginning...
    7) boot time cudve been improved...
    Tats all so far...tis is wat i have seen so far...feel free to share ur thoughts and experince my frnds....and so far iam loving MM :) Screenshot_20160331-000403.png
    #88
  9. pranayysharma
    pranayysharma , Mar 30, 2016 :
    1. When charging phone, sometimes the fingerprint sensor doeesnt work and requires password.
    The lock symbol show in place of fingerprint symbol in center bottom. Fixes itself once unlocked and relocked.
    2. Download speed doesn't show along with the progress bar anymore in notification drop down
    3. When there are no recent apps. Earlier touching anywhere on the screen would close the page and take back to the home screen. Now we must hit the back button to exit.
    #89
  10. Varun_Yadav001
    Varun_Yadav001 , Mar 30, 2016 :
    Ohhh
    Ohh ya i notice...well i think my wifi is bit slower :(
    #90
  11. Dhaval98
    Froyo Mar 30, 2016
    Dhaval98 , Mar 30, 2016 :
    Guys do we get marshmallow animations on oxygen is 3.0 like the ones on stock Android ?
    #91
  12. Eshan_Anand
    Eshan_Anand , Mar 30, 2016 :
    while rebooting into recovery it shows message as 'factory resetting' and then boots into recovery :p
    #92
  13. malidan
    Nougat Mar 30, 2016
    malidan , Mar 30, 2016 :
    I have N. Let me know when you have a half decent L never mind M:D
    Oh by the way it's rocked solid no FC, lag, stutters. This is what it's like when you have quality without software bodges:p
    #93
    nyzproof333 likes this.
  14. Varun_Yadav001
    #94
  15. jpswer
    Jelly Bean Mar 30, 2016
    jpswer , Mar 30, 2016 :
    Noticed a bug:
    When you reboot into recovery the title of the box which appears is "Factory data reset"
    #95
  16. Faktzi
    Faktzi , Mar 30, 2016 :
    wow do you only have 2mbs? lol
    #96
  17. Varun_Yadav001
    Hehhe...well Haven't recharge 4g pack that's why using my secondary connection :p
    #97
    Faktzi likes this.
  18. Moin2200
    KitKat Mar 30, 2016
    Was your bootloader locked?
    #98
  19. BitterHoney
    BitterHoney , Mar 30, 2016 :
    So Far I've found 1 bug:
    Once you remove lock screen security, the stored fingerprints were deleted, if you want to set screen lock again, you will have to set up the fingerprint again.(all 5 stored FPs will be deleted).
    If I found any other I will update.
    #99
  20. ratneshbhai
