49
Oxygen 3.0 buglist
Please select bugs in community build version of oxygen os 3.0, if you are facing any.
  1. Heating
    31.3%
  2. Fast Battery Drain
    57.2%
  3. Lagging
    12.7%
  4. Network issues
    14.9%
  5. Wifi issues
    20.5%
  6. Poor audio quality
    46.3%
  7. Loud ringtone
    16.8%
  8. Crashing of apps
    9.7%
  9. Others
    33.5%
Multiple votes are allowed.
  1. leonardste
    Cupcake Apr 13, 2016
    leonardste , Apr 13, 2016 :
    How to Screenshot a lack of bass? ...
    TheKhemist likes this.
  2. peppebi
    Froyo Apr 13, 2016
    peppebi , Apr 13, 2016 :
    I think I have this bug:
    Every day I use the phone at work to listen to Spotify music. Since I updated Spotify often stops playing music because can't find Internet connection (but the lte or hsdpa logo still remain on the screen).
  3. Nishchay Vaid
    Gingerbread Apr 13, 2016
    Nishchay Vaid , Apr 13, 2016 :
    One More Bug : Try to apply profile picture by draggingbdown status bar ( contact / profile icon ) . When i try to set a display picture it doesn't stick / save.
  4. luis905
  5. jdoggymcgee
    Gingerbread Apr 14, 2016
    jdoggymcgee , Apr 14, 2016 :
    I actually did a full factory reset AND reflash of OOS3, plus rolled back Google Play Services updates as someone suggested, and one of those must have worked, because my charging is back to normal speed and I have great battery life.
  6. ariblaze
    Jelly Bean Apr 14, 2016
    ariblaze , Apr 14, 2016 :
    13- give permission to whatsapp and facebook to access storage and contact
    17 - download app called AppLock from Playstore
  7. chirantanad
    Honeycomb Apr 14, 2016
  8. shruthanth
    Cupcake Apr 14, 2016
    shruthanth , Apr 14, 2016 :
    i am not able to change my ring tōne to a custom audio file in my storage although i tried to copy it to the ring tones folder, the audio file is not being listed in the ringtones list. plz help me
  9. arpitphillips
  10. prerak_99
    Donut Apr 14, 2016
    prerak_99 , Apr 14, 2016 :
    Faced one more bug when the phone heats up apps start crashing and phone restarts 2-3 times.
  11. ngydat
    Lollipop Apr 14, 2016
    ngydat , Apr 14, 2016 :
    There's definitely an issue with the slider : when I'm in general mode and I want to be in silent mode, the ringtone volume keeps being at the maximum. I have to switch a few times so it can work. Same thing when I'm in silent mode and I want to go back to general mode : the ringtone volume won't go up
  12. ngydat
    Issue already reported : https://forums.oneplus.net/threads/oxygen-os-3-0-beta-issues-with-alert-slider.441136/
    @majzok if you could add the bug in the original post, it would be nice thank you
    m1tch3m likes this.
  13. sumii0626
    Ice Cream Sandwich Apr 14, 2016
    sumii0626 , Apr 14, 2016 :
    Not sure if anyone has mentioned this bug but for adding fingerprints, it won't let me add any. Automatically says incomplete before pressing option is given or it lets me press once before it says incomplete. At most it let me press like 3 or 4 times before it said incomplete. Most of the time it doesn't even let me get to press and just skips to incomplete. Frustrating lol..
  14. aakashjhaveri
    aakashjhaveri , Apr 14, 2016 :
    I installed it the first day it was available
    Phone heating is back
    Battery drain is very evident. It's like the opposite of Doze is working when stand by
    Charging speeds are inconsistent
    Performance clearly isn't better
    Phone disconnects from wifi pretty often
    Seeking a video on QuickPic didn't work, if I were to pull down the notification tray. It starts the video over
    Notifications don't sound sometimes
  15. sheery86
    sheery86 , Apr 14, 2016 :
    sync.me is good thanx for this app....
  16. apisarenco
    apisarenco , Apr 14, 2016 :
    Has anybody noticed that during a call the screen is not always blocked by the proximity sensor? I've had this happen twice to me already - my cheek activated the loudspeaker while talking.
  17. embratoor
    embratoor , Apr 14, 2016 :
    when i tried to use the voice recorder it was very very bad
    after few minutes the voice start to be unclear at all
    i record my lectures and it's very important for me !!
    i think the noise cancellation mic suppress the teacher voice or something else ... please fix it
  18. embratoor
    second problem:
    during the calls the screen is not off all the time so battery drain + some times speakers activate or it mute the mic !!!
  19. Amber keone
  20. sfksuperman
    sfksuperman , Apr 14, 2016 :
    anyone tell me if there's a finale version going to launch in near future soon:???????????? or not.
