49
Oxygen 3.0 buglist
Please select bugs in community build version of oxygen os 3.0, if you are facing any.
  1. Heating
    31.3%
  2. Fast Battery Drain
    57.2%
  3. Lagging
    12.7%
  4. Network issues
    14.9%
  5. Wifi issues
    20.5%
  6. Poor audio quality
    46.3%
  7. Loud ringtone
    16.8%
  8. Crashing of apps
    9.7%
  9. Others
    33.5%
Multiple votes are allowed.
  1. marinobiagio
    KitKat Mar 30, 2016
    marinobiagio , Mar 30, 2016 :
    Mmm I think this is not a bug but.. if you use dark theme the search bar in the app drower change in flat gray.. and this is very ugly! :confused:
    ananthgnanasekaran likes this.
  2. iNoah
    Froyo Mar 30, 2016
    iNoah , Mar 30, 2016 :
    I'm having a really not good issue. Battery is draining waay too, fast like 12% in 10 minutes. Something called "App Optimization" is the culprit. Any suggestions?
  3. Plooge
    Froyo Mar 30, 2016
    Plooge , Mar 30, 2016 :
    App permissions menu loads for a second and then closes. There is no option to modify the app permisions.
  4. arex
    Froyo Mar 30, 2016
    iNoah likes this.
  5. adityapatel1495
    Cupcake Mar 30, 2016
  6. slytidar
    Donut Mar 30, 2016
    slytidar , Mar 30, 2016 :
    Very nice thread
    How is the oxygen 3.0 compared to cm13
    Is it worth switching from CM 13 to this?
  7. majzok
    Gingerbread Mar 30, 2016
  8. Prateek Sarna
  9. nikhilendrapratap
    otto2 likes this.
  10. Richard Vanisher
    Froyo Mar 30, 2016
    Richard Vanisher , Mar 30, 2016 :
    Lolllllll
    Here we go....
    Bugs do not Seattle lollll
    I will not do this buggy update...
    In a year they will release android ...
    Antonio32001 likes this.
  11. rohan.deshchougule
    Froyo Mar 30, 2016
  12. arex
    Froyo Mar 30, 2016
    arex , Mar 30, 2016 :
    Getting a strange red line in shelf which was not there before update
  13. Rauttis
    Rauttis , Mar 30, 2016 :
    I can confirm, the menu that shows all app permissions just closes instantly. There is another way however, just select a specific app from the apps menu and one of the options there is to change permissions for that one app.
  14. arex
    Froyo Mar 30, 2016
  15. ngaunguyens
    Honeycomb Mar 30, 2016
  16. drsahni
    drsahni , Mar 30, 2016 :
    BUG REPORT (someone else plz check to make sure its legit on another device)
    Turn on Location
    Select Location mode to battery saving OR device only
    Turn off Location
    On turning on the location again, it goes default to high accuracy always
    (i.e. it
    doesn't remember your choice)
    Sorry if someone else also posted this bug before
    Rest everything is super slick
    Love you OnePlus you have lived up to your standards
    manedark likes this.
  17. johnxianlinxu
    Eclair Mar 30, 2016
  18. rohan.deshchougule
    Froyo Mar 30, 2016
  19. Eshan_Anand
    Ice Cream Sandwich Mar 30, 2016
    Eshan_Anand , Mar 30, 2016 :
    enable it, its working
  20. ThePixelCutter
    ThePixelCutter , Mar 30, 2016 :
    \no idea havn't messed with anything so I guess not?
