oxygen 9.0.2 contacts problem
  1. D1541981280738 Donut Jan 8, 2019
    D1541981280738, Jan 8, 2019 :
    I have my oneplus 6t through T-Mobile. I just updated from 9.0.10 to 9.0.2 through settings update. after my phone is used for a little while I can't access my contacts to make a call.
    when I click on contacts the screen flashes and goes back to the home screen. if I reboot phone it fixes the problem temporary. having to reboot my phone way to many times just to access my contacts. help, thank you.
    sir1jaguar likes this.
  2. ironass Jelly Bean Jan 8, 2019
    ironass, Jan 8, 2019 :
    There is an issue on T-Mobile carrier minority variants that appears to be related to the carrier's Visual Voicemail. See...
    [Temp Fix] Phone App Crash [T-Mobile]
    D1541981280738 likes this.
  3. D1541981280738 Donut Jan 8, 2019
    thank you I followed the instructions. uninstall visual voicemail and reinstall. seems to have fixed the problem thus far.
    ironass likes this.
  4. N1543267098402 Cupcake Jan 13, 2019
    N1543267098402, Jan 13, 2019 :
    I don't have this problem but I have different problems. Even though the setting is disabled, my Pocket Mode keeps glitching and the screen won't come on when I double tap to wake or hit the power button. It usually takes about a minute before it will register any input at all and it seems random. I can't willfully replicate it. Also, my notifications with Telegram specifically are broken. I don't know if it's the app or the OS. The notifications will start to duplicate, stop expanding for replies, and then not clear for a while. The Telegram staff hasn't responded yet.
  5. Y1547352561569 Cupcake Jan 13, 2019
    Y1547352561569, Jan 13, 2019 :
    I'm facing issue while navigating to home screen... I'm having 1+6. and oxygen 9.0.2 navigating back to home from any application it gets hang for a sec (4-5 seconds)... I'm not understanding why this is happening... please do needful
  6. K1541595710466 Cupcake Jan 13, 2019
