25
OxygenOS Oxygen 9.0.2 full of bugs!
  1. C1541583366498 Cupcake Nov 7, 2018
    C1541583366498, Nov 7, 2018 :
    Also, night mode and reading mode have been disabled somehow.. unable to switch to reading mode...
    #61
  2. Gatoo Cupcake Nov 7, 2018
    #62
  3. Noni0ne Froyo Nov 7, 2018
    Noni0ne, Nov 7, 2018 :
    Only issue that I have is the notifications.
    When talking the notification sounds are extremely loud and distorted. Something needs to be done there and some notification sounds for apps like facebook/messenger are distorted.
    Tried reinstalling and other troubleshooting, its not helping.
    #63
  4. V1540842140128 Cupcake Nov 7, 2018
    V1540842140128, Nov 7, 2018 :
    Salut, OP 6 după ce am făcut trecerea la 9.0.2 nu pot răspunde la apel, suna telefonul dar nu pot răspunde rămâne blocat pe sonerie, se blocheaza in aplicatii, etc.
    #64
  5. KsSreedev Cupcake Nov 7, 2018
    #65
  6. Blackdem Cupcake Nov 7, 2018
    Blackdem, Nov 7, 2018 :
    better not to do it from my point of view
    #66
    Sethwhites likes this.
  7. Inturi Narendra Cupcake Nov 7, 2018
    #67
  8. KsSreedev Cupcake Nov 7, 2018
    KsSreedev, Nov 7, 2018 :
    I facing lot of issues..
    Huh!?
    #68
  9. Hiken Cupcake Nov 7, 2018
    Hiken, Nov 7, 2018 :
    mine is the same .. pitch black
    #69
  10. abyadav24 Cupcake Nov 7, 2018
    abyadav24, Nov 7, 2018 :
    Same issue. Shows a black spot instead of the user image. Apart from this, haven't faced any issues with the 9.0.2 update. I use only gestures and no issue of lag or keyboard freezing etc. I also use swiftkey. For those feeling the animation to be laggy, go to developer option and set all the animation scales to 0.5x.
    Can't comment on camera quality as i haven't used it extensively yet, although the night mode felt unimpressive in the couple of test photos i took. Battery seems fine, no abnormal drain. But the dash charging seems to have really quickened after this update! So far, seems like a good update.
    #70
  11. N1527694381692 Cupcake Nov 7, 2018
    N1527694381692, Nov 7, 2018 :
    Same issue again for me on 9.0.2. as it was on first Pie update. Emergency calls only while in my workshop where I would normally get 4G. I've reset network settings, checked APN's. I'll have to revert back to Oreo. I'm in the UK on ID Mobile.
    #71
  12. Mead76 Froyo Nov 7, 2018
    Mead76, Nov 7, 2018 :
    so glad I have not updated mine yet.....I'm not sure I ever will...
    #72
    L1535879402668 likes this.
  13. Pratik78 Froyo Nov 7, 2018
    Pratik78, Nov 7, 2018 :
    how did u flash brother please give me the steps!!!
    #73
  14. Deactivated User Nov 7, 2018
    #74
  15. C1541583366498 Cupcake Nov 7, 2018
    #75
    Mead76 likes this.
  16. AtLeastITried Cupcake Nov 7, 2018
    AtLeastITried, Nov 7, 2018 :
    I think this person is right. Everything is happening to me too.
    The WhatsApp thing happens to me any time I use any messaging app (discord, Google messages, WhatsApp)
    and the gestures are waaay to slow, and they're far worse than the old ones. You're right about it not being a bug, but it's definitely not an improvement.
    #76
  17. Kenny_Dedeurwaerder Cupcake Nov 7, 2018
    Kenny_Dedeurwaerder, Nov 7, 2018 :
    Messaging apps hang all the time too (whatsapp, instagram, ...), using Google keyboard and already cleared it's cache.
    It's like the phone thinks it receives a command to switch apps, and then just goes back to the homescreen after a couple of seconds...
    Frustrating.
    #77
    AtLeastITried likes this.
  18. F1539533726378 Cupcake Nov 7, 2018
    #78
  19. Sethwhites Cupcake Nov 7, 2018
    Sethwhites, Nov 7, 2018 :
    I have the same problem, and what the hell is that new slow animation when going on homescreen from some app. I thought that oxygen should be fast, this is like going few years back :)
    #79
  20. Equity Cupcake Nov 7, 2018
    Equity, Nov 7, 2018 :
    I don't know if it is but or not but I can't change home screen nor order of the screens. Does anyone know how to do it after last update?
    #80
