25
OxygenOS Oxygen 9.0.2 full of bugs!
  1. Prasan Soreng
    Cupcake Nov 7, 2018
    Prasan Soreng , Nov 7, 2018 :
    YouTube and Games automatically get paused after Oxygen 9.0.2 updates in my Oneplus 6, Help me to fix it
  2. Shehbaz_Baig
    Eclair Nov 7, 2018
    Shehbaz_Baig , Nov 7, 2018 :
    OP6 updates are making this beast annoying there wasn't any complain with Oreo version since it's upgraded to Pie bugs and issues are usual things now. I hope next update will address all these issues but I'm not going to update unless i conclude total research already did two times mistake seriously regretting upgrading to Pie and oxygen 9.0.2
    Trampdyna likes this.
  3. asaputrosnk
    Gingerbread Nov 7, 2018
    asaputrosnk , Nov 7, 2018 :
    l am not having all the problem mentioned , but had you tried clean system cache after update?
  4. Contivity
    Eclair Nov 7, 2018
    Contivity , Nov 7, 2018 :
    To me, "Recent" gesture is the state when you make the gesture to see all the open apps. It seems that when it "errors" out, swipe up or down would make it behave as if you're using the gesture to see the recent apps, but it's hold halfway, but it's in full screen. I'm not quite sure how to properly explain it.
    EDIT:
    Let me rephrase it the following way:
    • When the keyboard issue occurs, you can see that the screen freezes
    • Holding onto a screen with the finger up or down would make the screen be in the "Recent" state
    • This is the state equivalent to when you're making the gesture to see all the open apps
    Edit#2:
    Add video:
    Edit#3:
    Bug link: https://forums.oneplus.com/threads/after-unlock-using-keyboard-leads-to-recent-gesture.939486/
  5. haze.1986
    Froyo Nov 7, 2018
    haze.1986 , Nov 7, 2018 :
    Same issue. Everyone please feedback to OP!
    I did realise no issue with the keyboard resetting if I use oneplus launcher though
  6. Mrautani
    Cupcake Nov 8, 2018
    Mrautani , Nov 8, 2018 :
    Confirming following bugs noticed.
    - the keyboard disappearing randomly and often
    - hang ups on various apps and they all of a sudden disappear to the background (recent screen) as if a gesture would've been made, which was not (happened many times)
    Please Fix these! The phone was amazing before this update.
    Kumeresh and Gatoo like this.
  7. R1527273021917
    Cupcake Nov 8, 2018
    R1527273021917 , Nov 8, 2018 :
    My keyboard is also SwiftKey it not the keyboard man it's the latest update
  8. pblmndzn
    Cupcake Nov 8, 2018
    pblmndzn , Nov 8, 2018 :
    I have many of the issues described above:
    - keyboard / recent apps issue
    - apps restarting when changing between apps
    - reply from notification not working
  9. Equity
    Cupcake Nov 8, 2018
    Equity , Nov 8, 2018 :
    could you check if you can change home screen and screens order?
  10. Saket_Gupta1e
    Cupcake Nov 8, 2018
  11. KirinXHell
    Cupcake Nov 8, 2018
    KirinXHell , Nov 8, 2018 :
    Problem.
    1) Unable to pickup/reject call if voice call was received while my phone is lock.
    2) Unresponsive when multi-tasking (will hang for a few second then what have been open/entered will come out in a batch)
    3) Compared to the previous update/version, the new update easily overheat the phone
  12. ruimjpedro
    Eclair Nov 8, 2018
    ruimjpedro , Nov 8, 2018 :
    1. when I'm typing in WhatsApp the keyboard is dropping down and the window is freezing. Have to go to homepage open WhatsApp again and continue to type.
    Im also having this issue on SMS app, and also on facebook messenger, i use SwiftKey, im typing, keyboard closes and i have to close all and have to open it back again.
    Gatoo likes this.
  13. Deactivated User
    Nov 9, 2018
  14. Trampdyna
    Cupcake Nov 9, 2018
    Trampdyna , Nov 9, 2018 :
    On Pie 9.0.1 I had problems with disappearing keyboard, disappearing "clear recent apps" button, messed up recent apps (some were small, some insanly big), heavy battery drain (Oreo: 6-8h sot or 2-3days standby vs Pie: 3h sot or 1-2day standby), fingerprint sensor were slower and didn't give vibration feedback and something felt wrong with the camera (might be imagination). Icons on dropdown menu were awful and the volume slider became the dealbreaker since it's really annoying, inconsistent and blocks me while gaming if I accidently hit the volumebuttons. Also some apps were not updated to work with Pie at that point.
    If someone finds a way to change the position of the volume slider and the issues are solved I might give Pie another chance but for now I "upgraded" to Oreo using the downgrader some guy mentioned on the forum. Sorry I don't have the link but It worked and Oreo is awesome.
  15. PKFR4life
    Eclair Nov 9, 2018
    PKFR4life , Nov 9, 2018 :
    Same exact keyboard behavior but very sporadic for me. Hard to try replicating and recording for proof.
    And the latter issue, I realized that yesterday! 100% replicable. I'm not sure if I like that...
  16. F1540042976976
    Cupcake Nov 9, 2018
    F1540042976976 , Nov 9, 2018 :
    my cell is leaving network totally, when the network is weak n call disconnects several times whereas my one plus 6 is almost new, only 15 days old.
  17. Deactivated User
    Nov 9, 2018
  18. F1540042976976
    Cupcake Nov 9, 2018
  19. F1540042976976
    Cupcake Nov 9, 2018
    but it could not happened in my other Samsung mobile
  20. Kytharsis
    Nougat Nov 9, 2018
    Kytharsis , Nov 9, 2018 :
    It more than likely did, you just didn't notice it.
    Deactivated User likes this.
