25
OxygenOS Oxygen 9.0.2 full of bugs!
  1. Issa Bankz
    Eclair Nov 9, 2018
    quaddropop likes this.
  2. J1541753646892
    Cupcake Nov 9, 2018
    J1541753646892 , Nov 9, 2018 :
    After updating the OS, fast charging doesn't work. its taken 1.5 hrs approx to charge just 25% battery. When connected to the charger, the charging symbol also doesn't appear in d status bar. Is anyone facing this issue as well?
  3. Shehbaz_Baig
    Eclair Nov 9, 2018
    Shehbaz_Baig , Nov 9, 2018 :
    Night mode is total waste Upgrading to Oxygen 9.0.2 was a mistake next time will think several times before updating last 2 updates really made it an average phone before that it was matchless and blazing fast. Concluding it was delivering optimum performance when running Android oreo
    irfbaig and Trampdyna like this.
  4. Deactivated User
    Nov 9, 2018
  5. sai__ram
    Cupcake Nov 12, 2018
    sai__ram , Nov 12, 2018 :
    is there any way to resolve all these major and minor bugs?
    thanks in advance ^^
  6. JAGADISH BHATTA
    Ice Cream Sandwich Nov 15, 2018
    JAGADISH BHATTA , Nov 15, 2018 :
    There is no major bugs in this update only problem I am facing is front camera quality has been degraded because it applies skin smoothing which looks weird and previous gesture were good
  7. sai__ram
    Cupcake Nov 15, 2018
  8. JAGADISH BHATTA
    sai__ram likes this.
  9. sai__ram
    sai__ram , Nov 15, 2018 :
    so any solution to that and one more issue is with calls. frequently my calls are disconnecting. is there any problem with my mobile or is it a bug?
  10. JAGADISH BHATTA
    I am not facing any call drop issue.Check if you are getting good quality signal strength
  11. sai__ram
    my signals are good but still I'm getting call drops and am facing this issue from the day I updated to 9.0.2 and am using docomo as my operator.
  12. JAGADISH BHATTA
    I think its due to docomo,docomo signal quality is bad if possible try a different SIM and see if they also call drop
  13. sai__ram
    I'm thinking of same. but didn't face this issue in previous version so I was confused.
    for the user pic going black. any solution to that or have to wait for new update?
  14. badjack
    Froyo Nov 15, 2018
  15. G_TECH_partner_hizT
    Eclair Nov 15, 2018
    G_TECH_partner_hizT , Nov 15, 2018 :
    1.my fingerprint scanner sometime doesn't let me unlock the device
    2.my automatic display brightness is not working
    3.my screen freezes automatic while playing games and during normal usage
    4.the most important gesture are not working properly when I want go back it automatically goes to home screen
  16. JAGADISH BHATTA
    it's a known issue should be fixed in next OTA
  17. sai__ram
    thank you so much for clarifying my questions.
  18. irfbaig
    Donut Nov 15, 2018
    irfbaig , Nov 15, 2018 :
    absolutely right. new update has ruined the camera of oneplus6.
    ishwar12345 likes this.
  19. quaddropop
    Honeycomb Nov 16, 2018
    quaddropop , Nov 16, 2018 :
    Returning to the stock launcher has lowered the chance of the freezing issue, though it still happens when using the camera and switching to night mode (same goes with the Google Cam Port)
  20. Mrautani
    Cupcake Nov 23, 2018
    Mrautani , Nov 23, 2018 :
    Using stock launcher stopped the freezes. Fingerprint scanner doesn't respond to my fingers as it used to. (or it's just the dry winter air)
