45
Oxygen Installer
How is this
  1. Good idea
  2. Bad idea
  3. I'm rooted
  4. Potato
Multiple votes are allowed.
Results are only viewable after voting.
  1. marionb
    Honeycomb Mar 25, 2015
    marionb , Mar 25, 2015 :
    When I had my Nexus 5, Google came out with Lollipop and it was an easy OTA install. From Kit Kat to Lollipop, no problem. So why can't OPO do the same? Just asking.
  2. Rishabhbh
    veratoloz2005 likes this.
  3. hot_as_fire
    Jelly Bean Mar 25, 2015
  4. relic242
    KitKat Mar 25, 2015
    relic242 , Mar 25, 2015 :
    I think it will be easy to instal OxygenOS /stock CM11s recovery, no root , no custom recovery required/...
    Possible guide:
    1.
    download ROM package (zip) into phone,
    2. go to recovery /Turn Off phone, Volume - + Turn On/,
    3. wipe data/factory reset
    4.
    apply update /and choice downloaded ROM package/
    note: OxygenOS package will be signed... - no problem using stock recovery
    (4.1 wipe cache partition - for sure...)
    5. reboot system now
    6.
    done
  5. Rishabhbh
  6. Hans P.
    Ice Cream Sandwich Mar 25, 2015
  7. vivu.vivek
    Gingerbread Mar 25, 2015
    vivu.vivek , Mar 25, 2015 :
    I like the concept. It would be nice if it also takes a bakcup of existing ROM. Just in case if we don't like we can revert back to original ROM :)
  8. Rishabhbh
    Tyronekramsey likes this.
  9. relic242
    KitKat Mar 25, 2015
  10. Hans P.
    Hans P. , Mar 25, 2015 :
    I used CM Installer for my GS3 and it wiped everything.
  11. wibblemonster
    wibblemonster , Mar 25, 2015 :
    I dont want to root my phone for one simple reason. A large number of financial, banking and streaming apps wont work if they see a phone is rooted.
    I just want a quick and easy way of installing a stable, clean oxygen os if I choose.
    Ive absolutely no interest in flashing different roms. I bought the opo because it offered the best spec at the price...nothing more.
  12. manjake
    manjake , Mar 25, 2015 :
    The oneplus one is a phone for tech enthusiasts and flashing a rom is very easy, it's a cleaner method than using an installer anyways
    relic242 likes this.
  13. Cuerex
    KitKat Mar 25, 2015
    Cuerex , Mar 25, 2015 :
    It's pointless, you know why? Because the effort is not worth it.
    Oxygen OS is only for OPO. Cyanogenmod is for a bunch of other devices.
    It might even increase the cost of the OPO.
  14. Neth
    Neth , Mar 25, 2015 :
    Bad idea. Why? Because people will find a way to screw up and won't realize where and how they did it which makes it impossible for them to recover their phones.
  15. sparkie
    sparkie , Mar 25, 2015 :
    Leave your phone the way it is then. Its quite possible that Oxygen OS may appear rooted to some appliactions, it currently happens on 11S with some apps.
  16. veratoloz2005
    Lollipop Mar 25, 2015
    veratoloz2005 , Mar 25, 2015 :
    Until the contract between OP and CM is over, OP will keep Oxygen for flashing only. After the deal is over, OTA will follow. Of course, if Oxygen succeeds.
  17. slickjimmy04
    Froyo Mar 25, 2015
    slickjimmy04 , Mar 25, 2015 :
    This is a important issue. Convenience coupled with the prospect of damaging one's device is more than enough reason to provide a pain free installation method for OXYGEN. NEVER SETTLE!!!!
  18. Tyronekramsey
    Tyronekramsey , Mar 25, 2015 :
    That's not gonna be possible. Maybe if you wipe everything
  19. Loggoman
    Cupcake Mar 25, 2015
    Loggoman , Mar 25, 2015 :
    I am wondering why they do not accept a rooted phone?
  20. Cuerex
    KitKat Mar 25, 2015
    1. because they're jews
    2. if a virus infests your rooted device, the data which is secured in the app might get leaked through the root administration rights
    neyzen69 likes this.
