oxygen os 10.3.1 problems
  1. F1547936961269
    Cupcake Feb 9, 2020
    F1547936961269 , Feb 9, 2020 :
    in the new oxygen os 10.3.1 the notch display setting is broken. when you choose the hidden setting the date and icons move down on top of the app screen, instead of using the black bars around the notch like they used to.
    quite dumb setting now.
    Regan.9 likes this.
  2. Q1581298606473
    Cupcake Feb 10, 2020 at 2:21 AM
  3. Arjen421
    Cupcake Feb 15, 2020 at 8:59 AM
    Arjen421 , Feb 15, 2020 at 8:59 AM :
    If you're running magisk with call recorder enabler you need to disable reboot enable reboot. Atleast thats what causing no sim detected on my 6
  4. DrJMun
    KitKat Feb 15, 2020 at 3:15 PM
    DrJMun , Feb 15, 2020 at 3:15 PM :
    The problem with the notch display on 10.3.1 is a known problem. We'll just have to wait and see if a future update fixes the problem.
  5. Tludwick
    Cupcake Feb 16, 2020 at 11:04 AM
    Tludwick , Feb 16, 2020 at 11:04 AM :
    Since installing the Oxygen 10.3.1 update a few days ago, I have no mobile reception. In other words, my phone has ceased to have any calling or texting function. The phone recognized the SIM card, but there is no reception. It works only on wifi. I have already hard restarted, wiped the cache, and called my mobile phone service provider. Nothing works. Please help.
  6. DrJMun
    KitKat Feb 16, 2020 at 5:40 PM
    DrJMun , Feb 16, 2020 at 5:40 PM :
    When you say you hard restarted do you mean you reformatted? I assume you also tried resetting wifi, mobile and bluetooth connections? Odd the carrier cannot offer any help.
    Kytharsis likes this.
