2
Oxygen os 11 using about 33gb of system storage on one plus 8 via OnePlus 8
  1. Rishabssg
    Cupcake Nov 6, 2020
    Rishabssg , via OnePlus 8 , Nov 6, 2020 :
    After updating to oxygen os 11 I realised that my storage was getting full and when I checked it out, it turns out that the system storage was using about 33 gb which seems a lot.Any suggestion to reduce this would be helpful.
    dlakshmanan99 and O1592302217281 like this.
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 6, 2020
    Best Answer
  3. O1592302217281
    Eclair Nov 6, 2020
  4. camohan
    Moderator Moderator Nov 6, 2020
    camohan , Nov 6, 2020 :
    Hi there, this is what the Android 11 requires as a space to function comfortably. Unfortunately there is no way to reduce or compress this as these are system files.
    Hope this helps.
    Rishabssg and Liehjan like this.
  5. Rishabssg
    Cupcake Nov 6, 2020
    Ok thanks [e]1f44d[/e]
  6. Rishabssg
    Cupcake Nov 6, 2020
    Ohhhh ok thanks [e]1f44d[/e]
    Swejuggalo likes this.
  7. O1592302217281
    Eclair Nov 6, 2020
    O1592302217281 , via OnePlus 8 , Nov 6, 2020 :
    Ok thanks
  8. U1573139994427
    Cupcake Oct 3, 2021
    U1573139994427 , Oct 3, 2021 :
    Mine too. Nothing you can do that I can find. You can Wipe the Cache and Restart but that frees up inly about 1GB as I do it often. Try it? The problem is there's Android which is about 15GB and then there's Oxygen!
