372
Oxygen OS 2.0.1 - First OTA for OnePlus 2 rolls out today
  1. adamski07
    Gingerbread Aug 23, 2015
    adamski07 , Aug 23, 2015 :
    did you lose any data by doing this?
  2. jrlefrancois
    Honeycomb Aug 23, 2015
    jrlefrancois , Aug 23, 2015 :
    Nope nothing changed but make sure you read the instructions and follow the right ones. Back up your stuff in case!
  3. adamski07
    okay thank you. I was using the 40 MB earlier. I hope the full ROM will work flawlessly. Thanks again.
  4. navi_een
    Eclair Aug 23, 2015
  5. adamski07
    jrlefrancois likes this.
  6. jrlefrancois
    You're welcome. Still having some issues with my home buttom but only when using my thumb. Cheers!
  7. adamski07
    Same here. As finger scanner, it is perfect, but as a home button, it is not as sensitive as it should be. Using it as the home button, I had to apply more pressure while not touching it long enough for it to go on Google Now. I think they still need to work on that. Maybe, making it more sensitive is a good idea. I also think that they should have gone with flushed finger scanner instead of having that "not so good looking" fake button on there since it is not working as mechanical button anyway.
  8. jrlefrancois
    I disabled double- and long-press on home key only to avoid that issue. Double-tap on right or left is fine with me. I'll let home have all the luck it can get since it's still a little weak. I swear though if I use my index finger it always works--just not my thumb.
  9. rams737
    Eclair Aug 23, 2015
    rams737 , Aug 23, 2015 :
    The update did not fix the adoptive brightness issue. It is not so Smooth and responsive
    shark147 likes this.
  10. ssb_k1ng
  11. avanivichu
    Cupcake Aug 23, 2015
  12. coooolboyabhi
    Donut Aug 23, 2015
  13. ganesh131514
  14. ganesh131514
  15. Nikhil Jawale
  16. vijaywidluv
    Ice Cream Sandwich Aug 23, 2015
    vijaywidluv , Aug 23, 2015 :
    I got this phone yesterday morning. Its running perfectly fine cant complain. But am still on oxygen 2.0 I didnt got ant ota updates so far.should I do it manually or I should wait?? I am in India
  17. amarsaleem
    amarsaleem , Aug 23, 2015 :
    Where is the update? My phone still reads Oxygen Version 2.0.0 and when I try to update it says Your System is Up to Date ........
    It is OTA ... Over the Air ... Right? It should be available through Settings panel.
    What gives?
  18. viswapraneeth
  19. sn00pster
    Froyo Aug 23, 2015
    sn00pster , Aug 23, 2015 :
    When I boot into recovery I don't get any options which say "update" as the posts earlier indicate as the method to apply the Ota.
    All I have is install from zip and install from USB.
    Thoughts?
  20. gjegadeesh
    jdneilso likes this.
