10
Oxygen OS 3.1.2 bugs thread
  1. OneplusMike64
    Eclair Jun 20, 2016
    OneplusMike64 , Jun 20, 2016 :
    Sorry that's just incorrect : I get all notifications on my old phone (also running android 6.0.1) that includes : whatsapp, gmail, youtube, android authority, weather, facebook and so on, and i get NONE on my OP3. Whatsapp was affected with people that use the beta, not the ones on the stable releases.
  2. Tsugaru87
    Gingerbread Jun 20, 2016
    Tsugaru87 , Jun 20, 2016 :
    I also got this problem... Android system draining too much...
    dfence likes this.
  3. ajaymurali
    Froyo Jun 20, 2016
    ajaymurali , Jun 20, 2016 :
    Issue that I am facing on my one plus 3 is while making Skype video calls. I am able to hear the other person but for them my voice is breaking and sometimes not audible at all. Checked the same with nexus 5 (both running on same version of Skype app) and it is fine.
    Did anyone face this issue and is there any solution for it?
  4. stuart_Foy
    stuart_Foy , Jun 20, 2016 :
    I noticed the speaker phone quality is very poor. I have to use a headset.
  5. ajaymurali
    Froyo Jun 20, 2016
    For me , while using headset also, the other user is not able to hear me at times, and also not clear for most of the time. Not sure if it is because of some noise cancellation working really more than desired
  6. Zero389
    Cupcake Jun 20, 2016
    Zero389 , Jun 20, 2016 :
    Oxygen has no Blacklist?
    And also no mobile data in quick settings. Would like to have this inside...
  7. arvamichal
    Eclair Jun 20, 2016
    arvamichal , Jun 20, 2016 :
    Have someone issue with gallery, or other apps using photo / gallery apps? When i open gallery, i have no images, its empty, but with file manager a can find all my photos in OPO3 (DCIM folder and Pictures folder). But cant view it in gallery (other apps - aviary, snap camera, instagram, FB ... ). All apps have permissions, but it doesnt help. OPO3 Rooted.
  8. Arbingr8
    Honeycomb Jun 20, 2016
    Arbingr8 , Jun 20, 2016 :
    Is otg working? I have tested its not working in my op3
  9. ajaymurali
    Froyo Jun 20, 2016
    Returned my OP3 due to the above issue. Waiting for replacement
  10. GeesRiK
    Ice Cream Sandwich Jun 21, 2016
    GeesRiK , Jun 21, 2016 :
    Yep, no way to set vibration on when the phone rings. I have the same problem
  11. GeesRiK
    Also, it was the same with the OP2 camera, but when is slow motion zoomed in so much? really annoying when you switched from the normal record mode to this, you have to change the distance you are from the subject.
  12. vinitkhandka
    Eclair Jun 21, 2016
    vinitkhandka , Jun 21, 2016 :
    This happens on my Oneplus 2.
  13. stuart_Foy
    Gingerbread Jun 21, 2016
    stuart_Foy , Jun 21, 2016 :
    works fine here!
  14. F_Joseph_Bilikiewicz_WyJ
    Cupcake Jun 21, 2016
    F_Joseph_Bilikiewicz_WyJ , Jun 21, 2016 :
    Got the phone yesterday and this is my first experience with OnePlus. Was smooth sailing until this morning when I had it hooked up to the Dash car charger. The phone randomly rebooted multiple times before and after connecting to bluetooth. I unplugged the charger and it was reboot-free for the remainder of the ride while connected. Any ideas?
  15. Emalinho
  16. Jasonfran
    Donut Jun 21, 2016
    Jasonfran , Jun 21, 2016 :
    WiFi speed seems a bit slow. Should be 150mbps max but I can't get over 100mbps.
  17. Tsugaru87
    otto2 and Emalinho like this.
  18. EatDatRice
    Eclair Jun 21, 2016
    EatDatRice , Jun 21, 2016 :
    Anyone facing problems with the microphone? Sound of the microphone is really bad!
  19. Emalinho
  20. babybug
    babybug , Jun 21, 2016 :
    anybody facing issues with the app accessibility? I have tried different app lock and faced the same problem with accessiblity service being turned off every time I reboot the phone.
    Also I am using Mi band 1s, and it randomly keeps pairing BT with the handset so all my tracking is off.
