148
Oxygen OS 5.1.3 OTA for the OnePlus 5 & 5T
  1. G_Manmohan_Yadav_jemi
    Donut Jun 27, 2018
  2. U1530114419230
    Cupcake Jun 27, 2018
    U1530114419230 , Jun 27, 2018 :
    Hi Team, Good day!
    Battery is getting drained drastically after updated to 5.1.3
    kindly suggest me what should I do?
  3. DinandBajo
    DinandBajo , Jun 27, 2018 :
    Found a bug in notes app.. when deleting text the cursor randomly moves to the left side leaving undeleted characters to the roght of the cursor.. tried deleting cache of notes app and launcher but the issue still exist....
    battery seems the same with nougat.. what i did.. clear cache IMMEDIATELY before and after update in recovery and thats it... but I'll continue to monitor battery capacity and give you guys update.
    Never Settle :)
  4. B1530116819495
    Donut Jun 27, 2018
    G_T_Bennett and Rakshit_Patil like this.
  5. mclarenf1lm
    Eclair Jun 27, 2018
    btraju143 likes this.
  6. nikhilgarg.98
    Donut Jun 27, 2018
    nikhilgarg.98 , Jun 27, 2018 :
    same problem brother.....hope they fix it in their next update
  7. btraju143
    Eclair Jun 27, 2018
    btraju143 , Jun 27, 2018 :
    Mine too.. Need to reboot and then it works. Hope they address the issue soon
    mclarenf1lm likes this.
  8. Q1516456788527
  9. unicornadorer89
    Froyo Jun 27, 2018
  10. Gcabalos
    Cupcake Jun 28, 2018
    Gcabalos , Jun 28, 2018 :
    otg usb reading 0b on files after update. placed my usb to other devices.. working properly. anyone have the same issue?
    Ravi BINAVAT likes this.
  11. Eustacio Sealy
    Ice Cream Sandwich Jun 28, 2018
    Eustacio Sealy , Jun 28, 2018 :
    may I ask why have you placed the update on a USB drive,well if have rooted your phone did you extract the download file ,the update is a OTA
    Gcabalos and Ravi BINAVAT like this.
  12. rahulr77.rr
    Donut Jun 28, 2018
    rahulr77.rr , Jun 28, 2018 :
    man the battery life reduced drastically after this update,
    I have never faced such a issue . now actually without usage also the battery is getting reduced at a faster rate. I have tried all wipecache partition, cache clear and everything, still no positive result
    Eustacio Sealy likes this.
  13. Zaphodrocks
    Zaphodrocks , Jun 28, 2018 :
    You have a wakelock issue. Try to figure out which application is causing it. There is nothing wrong with the update as such, otherwise everyone would have this issue.
    MikeG247 likes this.
  14. rahulr77.rr
    Donut Jun 28, 2018
    is there anyway to do it, I mean to find which application is causing it. Also, after the update I have not installed any apps
  15. Zaphodrocks
    Post your battery stats. Both the screens. I'm sure there must be a solid line against "awake". And I hope you wiped the cache from the recovery menu. Poorly written apps, even ones already on the phone, misbehave after an update. After wiping the cache from recovery, it may take a couple of days for the battery to stabilize. If it still persists, you have to hope for an update from the app that's causing the issue.
  16. Gcabalos
    no im using the otg function of the phone for playing movies. befor the update its working but now it says all of the files in 0bites.
  17. krinalmehta
    krinalmehta , Jun 28, 2018 :
    After installing this update, my OP5 battery is draining like anything. Possible bug with the update? How do I rollback?
  18. danishdaycare
    danishdaycare , Jun 28, 2018 :
    Try clearing cache in recovery if android system is eating up your battery. Usualy solves battery drains.
  19. 5star02707
    5star02707 , Jun 28, 2018 :
    every time you update i would suggest clearing cache in recovery. also if problem still persist flash the latest Full Rom instead of just the short OTA one
    G_T_Bennett likes this.
  20. alimonu2011
    Eclair Jun 28, 2018
    alimonu2011 , Jun 28, 2018 :
    after this update I am facing battery drain problem.. battery not working properly like last update
