148
Oxygen OS 5.1.3 OTA for the OnePlus 5 & 5T
  1. Aziz_Amin_Oneplus
    Jelly Bean Jul 22, 2018
    Aziz_Amin_Oneplus , Jul 22, 2018 :
    You will don't worry, late but good, for now Oreo running good, you can check good customization like Android P theme or Android P launchers in play store if you are bored for now.
    AshikZaman likes this.
  2. danishdaycare
    Ice Cream Sandwich Jul 22, 2018
    danishdaycare , Jul 22, 2018 :
    By reading the instructions how to install beta. If you don't know, don't install the beta.
    maortrol likes this.
  3. DogeAlpha
    Honeycomb Jul 22, 2018
    DogeAlpha , Jul 22, 2018 :
    Always on display drains battery.
    The oneplus 6 had it on release but it got removed really quick.
    bidawi111 likes this.
  4. abouaymane
    Cupcake Jul 22, 2018
  5. lakulaku
    lakulaku , Jul 22, 2018 :
    This issue seems to be very popular all over the world in different forums: device looses sound.
    My 5T worked fine until now, latest update to 5.1.3. Sound has gone and there's no way to get it back. IT IS NOT about settings or too full memory, or just to reboot. It does not come back. Until... Then, middle to typing a message I sudden start to hear the keypresses. Sound is back and works for 5min to 1 hour and then disappears again without a touch. No notifications, no music, no ringtones. Slider works ok. This is clearly something with OxOS. And there must be thousands of people with same problem. This makes the phone more or less useless...
  6. DogeAlpha
    Honeycomb Jul 23, 2018
    Ramesh TP likes this.
  7. G_Bharat_Prabhas_NjsN
    Gingerbread Jul 23, 2018
  8. G_T_Bennett
    Jelly Bean Jul 23, 2018
    G_T_Bennett , Jul 23, 2018 :
    Did you want to explain what the issue is with your battery?
  9. danishdaycare
    Ice Cream Sandwich Jul 23, 2018
    danishdaycare , Jul 23, 2018 :
    Billions and billions and billions....
  10. sachkharb
    Ice Cream Sandwich Jul 24, 2018
    sachkharb , Jul 24, 2018 :
    don't know why people scream so much about battery n all.. try to be humble.
    My SOT on 5.1.3 is 10+ hour. I update some apps from playstore and suddenly it drops to 4 hours. Android System takes lots of battery.
    I was worried about it. Then I completed only one recharge cycle and clear cache in recovery and my SOT is back on track.
    Here are very useful threads in this forum about battery calibration and battery backup. Try to read and apply them. I am sure you'll have a better battery backup.
    And one more imp thing- Battery backup is purely depend how you use your mobile, your network coverage, your background apps etc. So it's not necessary that you'll have same backup as others.
    5star02707 likes this.
  11. F1532426386931
    Cupcake Jul 24, 2018
    F1532426386931 , Jul 24, 2018 :
    I am on one plus 5t oxygen os 5.1.3 i didnt get any update after that there are two major updates open beta 11 and open beta 12 as shown in one plus site but whenever i try to check it says up to date, i dwnload both open beta 11 and open beta 12 from site tried to update manually by recovery but it says installation failed in both updates, so how should i update to latest version i even tried by adb sideloading firmware but still no success plx help me to update to open beta 12 which is latest for one plus 5t,i have tried chnge of vpn to canada but still no succes, i have bought one plus 5t from singapore is tht causing issue for update
  12. lanecreek
    Froyo Jul 24, 2018
    lanecreek , Jul 24, 2018 :
    these are two different streams. 5.1.3 is the latest stable version. if you want to install the latest betas, then you got to follow the instructions in the corresponding thread.
    MikeG247 and F1532426386931 like this.
  13. Ramesh TP
    Eclair Jul 24, 2018
  14. Chiran_OP5
    Honeycomb Jul 24, 2018
    Chiran_OP5 , Jul 24, 2018 :
    soon in this month for sure.
  15. F1532426386931
    Jst tell me which is latest update for one plus 5t i m on oxygen os version 5.1.3 n m confused between open beta 12 can i install it over 5.1.3, i tried but installation fail
  16. F1532426386931
  17. G_T_Bennett
    Jelly Bean Jul 24, 2018
    G_T_Bennett , Jul 24, 2018 :
    Yes it is safe, yes there are bugs. Open Beta 12 is the latest for 5T and open Beta 14 is the latest for 5. You need to download Open Beta 10 or 12 before proceeding. Forums are littered with instructions on how to do this.
  18. F1532426386931
    I dwnloaded 12 but it say installation failed so what u suggest should j stay on 5.1.3 is this the latest stable version on what version are u rt now
  19. G_T_Bennett
    I clearly said you need to download Open Beta 10 first.
  20. F1532426386931
