Oxygen OS 5.1.9 issues
  1. T1530550668236 Donut Jul 23, 2018
    T1530550668236, Jul 23, 2018 :
    After installing the update 2 days ago , i am facing random app crashes, till now two of my apps namely Youtube and Beebomco have closed abruptly. Is someone else also facing this issue? If yes please let the community know.
  2. Prcko Jelly Bean Jul 23, 2018
  3. T1530550668236 Donut Jul 23, 2018
  4. csgovind Eclair Jul 23, 2018
  5. T1530550668236 Donut Jul 23, 2018
    personally , i can't see a noticable change in camera performance.
    Durgesh8 and kn_raghavendra like this.
  6. csgovind Eclair Jul 23, 2018
    csgovind, Jul 23, 2018 :
    agreed. oneplus says google lens will work automatically but its like the previous one only n no beauty mode can also be seen.
    oneplus should resolve this issue asap
    kn_raghavendra likes this.
  7. rahulrdeo Froyo Jul 23, 2018
    rahulrdeo, Jul 23, 2018 :
    My OP6 camera keeps hunting for focus on close up objects in low light scenario.
    Durgesh8 likes this.
  8. T1530550668236 Donut Jul 23, 2018
    haven't tested the camera in low light since the update , will do so soon.
  9. T1530550668236 Donut Jul 23, 2018
    There is beauty mode in selfie camera now. Cant say much about how good it is though.
  10. csgovind Eclair Jul 23, 2018
    how to recognise the mode?
  11. T1530550668236 Donut Jul 23, 2018
    It is not much a mode , more like a setting. You open your front camera , look on the right bottom corner you'll see a circle with a person shape with stars , tap that and you can set how much you want that beauty setting. Do test it and let us know what you think.
  12. csgovind Eclair Jul 25, 2018
  13. csgovind Eclair Jul 25, 2018
    csgovind, Jul 25, 2018 :
    how google lens update will work with back camera as i have update the same and while clicking on any object no details are showing. kindly share your views
  14. T1530550668236 Donut Jul 26, 2018
    T1530550668236, Jul 26, 2018 :
    For that you first have to swipe up in the camera app , select google lens then u will be able to use it.
  15. csgovind Eclair Jul 26, 2018
    csgovind, Jul 26, 2018 :
    i had seen the option and there is no option of google lens displaying. i think proper update has not been given by oneplus.
  16. akoolshrestha Cupcake Jul 26, 2018
    akoolshrestha, Jul 26, 2018 :
    I am able to get the option properly.
    You may want to check the change logs again and if it "Google lens support" shows in it, then you may have to redo the update.
  17. O1558637267902 Cupcake May 23, 2019
    O1558637267902, May 23, 2019 :
    i took a couple screen shots. how can I forward them to you guys. those screenshots explain better the issue I hade with the software..
  18. Kytharsis Lollipop May 23, 2019
    Kytharsis, May 23, 2019 :
    What software exactly? 5.1.9 is horribly old.
  19. O1558637267902 Cupcake May 23, 2019
  20. Kytharsis Lollipop May 23, 2019
    Wait, no, I meant to say which firmware version?
