35
Oxygen OS - First Impressions, Reviews mega thread [Merge]
Do you Plan on Flashing Oxygen OS?
  1. Yes,It seems the right choice
    30.5%
  2. No,I'll Wait for CM12S
    69.5%
  1. mydroid
    KitKat Apr 4, 2015
    0verlord likes this.
  2. ThomoJames97
    Gingerbread Apr 4, 2015
    ThomoJames97 , Apr 4, 2015 :
    When I first got my OPO, the battery life was incredible, then the most recent CM11s update made it drain quicker, now, with this update, the battery life is still the same; draining, rather than how it was before...
    hugopiovesan likes this.
  3. Henry80
    Ice Cream Sandwich Apr 4, 2015
    Henry80 , Apr 4, 2015 :
    Guys,
    could you flash oxygen_1.0.0_flashable.zip using TWRP v.2.8.6.0?
    I get a zip signature verification FAILED.
    Thanks in advance if you can help me.
  4. hugopiovesan
  5. DarkSteemex
    DarkSteemex , Apr 4, 2015 :
    have you extracted md5?
  6. mydroid
    KitKat Apr 4, 2015
    mydroid , Apr 4, 2015 :
    Yes it needs some closed source controlling to achieve a stable customization I am rooting for v2 and more for oxygen os ...... But stay stock for now is wonderful as I always wanted a stock nexus one plus one!
    astralbee likes this.
  7. hugopiovesan
    hugopiovesan , Apr 4, 2015 :
    the file you need is inside the zip that you downloaded...
  8. lolleoshen
    Froyo Apr 4, 2015
  9. Henry80
    Yes, I've checked it and it's ok.
    I've also copied it in my 1+1, with the flashable_zip.
    Still, can't flash :(
  10. hugopiovesan
    that depends, if you have unlocked bootloader, is not needed. If your bootloader is locked, you need to wipe EVERYTHING to unlock it.
  11. ThomoJames97
    I didn't have to put the MD5 in, but just try copying the .md5 file to the same location as the zip folder, on your OPO. @Henry80
  12. ThomoJames97
    Have you backed up your files and done a factory reset?
  13. Henry80
    No hugo, I've already extracted that zip.
    Look at my message.
    I get a zip signature verification failed when trying to install oxygen_1.0.0_flashable.zip
  14. candrakho
    Eclair Apr 4, 2015
    candrakho , Apr 4, 2015 :
    Damn. Miku ohashi is clearly better than mia khalifa. Yes, it is my opinion. Lol
    Ceasedd likes this.
  15. Henry80
    Yes, I've manually wiped: system+data+dalvik+cache
  16. jonathangall
    Cupcake Apr 4, 2015
    jonathangall , Apr 4, 2015 :
    Yes the camera options are disappointing. But I'd be surprised if either there wasn't an Oxygen camera probably in production. But failing that, Google camera will naturally upgrade it's fps/4k abilities in future, which could be soon for all we know.
    Shame they didn't manage to squeeze in a few more features, but building a solid base seems like a good place to start.
    psionandy likes this.
  17. Henry80
    Thanks Thomo, I've done that.
    Still can't install. :(
  18. ThomoJames97
    I know this isn't helpful, but CM12s will be a lot better than Oxygen OS. Oxygen OS is just stock Android with gestures. I've got it and it really isn't all that great. If I were you, I'd just wait for the OTA for CM12s.
    tbalden likes this.
  19. DarkSteemex
    i extracted files wiped everything and installed it via otg
  20. OlfakD
    Jelly Bean Apr 4, 2015
