35
Oxygen OS - First Impressions, Reviews mega thread [Merge]
Do you Plan on Flashing Oxygen OS?
  1. Yes,It seems the right choice
    30.5%
  2. No,I'll Wait for CM12S
    69.5%
  1. osaz_oe
    Honeycomb Apr 4, 2015
    osaz_oe , Apr 4, 2015 :
    More apps? I guess...
  2. Vazovskiiii
    Froyo Apr 4, 2015
    Vazovskiiii , Apr 4, 2015 :
    Install the twrp recovery using fastboot and then just flash the super su 2.46 from guide topic works like charm
    azp3 likes this.
  3. ThomoJames97
    Gingerbread Apr 4, 2015
    ThomoJames97 , Apr 4, 2015 :
    How do you get them?
  4. ThomoJames97
    I have Oxygen OS and can give you wallpapers - just need to know how to get them...
  5. CaptainZap
    CaptainZap , Apr 4, 2015 :
    Can anyone else confirm this ? This is the main reason I plan on moving to O2OS...
  6. osaz_oe
    It was obviously going to be Oxygen OS first, as that was the plan right out of the gate going by the order before. And theoretically they would want people to adopt it as much as possible to generate feedback so they know where to go from here. Just my opinion...
    Facilon likes this.
  7. GuW
    GuW , Apr 4, 2015 :
    The one thing I was hoping was fixed *sigh*
    Atleast in CM you can denie it under the privacy settings
  8. Setting.out
  9. osaz_oe
    You have to create a system dump and put them all in a zip file
  10. udeshvirk
    udeshvirk , Apr 4, 2015 :
    YOu can change it in Setting > Buttons
    firenxe likes this.
  11. tkerabbi
    tkerabbi , Apr 4, 2015 :
    I think we all got spoiled with 11s. Which is why everyone is shitting on this ROM IMO. Im going to wait for CM12s even tho im running Exodus...
    dhwaneetbhatt likes this.
  12. Axf
    Froyo Apr 4, 2015
    Axf , Apr 4, 2015 :
    Has anyone gotten v4a working on Oxygen? I tried flashing it with fix zips and it installs fine but when I turn it on the sounds all effed up. AND after installing the drivers, but not enabling v4a it speeds up all the sounds which was strange.
  13. andrew3gs
  14. simon1+
    Donut Apr 4, 2015
  15. rrainwater
    Ice Cream Sandwich Apr 4, 2015
    rrainwater , Apr 4, 2015 :
    No. OxygenOS was never going to be an OTA. There is no way to provide an OTA to a completely different OS. If anyone said it was going to be an OTA, they had no clue what they are talking about. Subsequent updates will be OTA once you install it though.
    tommy6808 and hmzuleta like this.
  16. csukcc
    csukcc , Apr 4, 2015 :
    I have been using CM12.1 and have to say it has much better battery life compared to CM12. I am still testing this, but from what i have seen so far it is on par with CM12. Hopefully we'll see the 12.1 update soon. But I do like the fact this is based on AOSP and not CM12, which means we are not tied to the CM release schedule :)
  17. bingster
  18. andrewchai
    Cupcake Apr 4, 2015
    andrewchai , Apr 4, 2015 :
    Tested OxygenOS for about an hour now
    - Really feel like Nexus, light and Fast.
    - Im disappointed with the camera, it is using stock camera. No more rich photo editor feature as it used to be.
    Just my 1 cent
    Thearcade12 likes this.
  19. andrewchai
    Cupcake Apr 4, 2015
    Mine too, but after factory reset it works as normal.
    andrew3gs likes this.
  20. Fatih.Kilic
    Donut Apr 4, 2015
