89
Oxygen OS Issues Thread
  1. Nirav Mistry
    Cupcake Oct 21, 2015
    Nirav Mistry , Oct 21, 2015 :
    After updating to 2.1.1 my phone is getting heated very fast. Playing a simple game like COC for ten minutes heats up the phone to 40°. One plus team I don't know when will you release a stable version. Still Mortal Combat X is crashing on my phone.
  2. bshergad
    Froyo Oct 22, 2015
    bshergad , Oct 22, 2015 :
    There is another issue in camera. Taking a picture with flash on turns off my display after clicking the picture.
    Currently using oxygen OS- 2.1.1 :(:mad::confused:
  3. briang561
    Donut Oct 22, 2015
    briang561 , Oct 22, 2015 :
    Everything runs smoothly on 2.1.1 for now
  4. naman10
    Donut Oct 22, 2015
  5. ashwinguy
    Gingerbread Oct 22, 2015
    ashwinguy , Oct 22, 2015 :
    Why I am getting low antutu benchmark of 44397 only running original Oxygen OS 2.1.1 :(
    can anybody pls help??What is the scores other India customer here are getting in it ?
  6. dr.karthik k
    dr.karthik k , Oct 22, 2015 :
    does anybody having probelm with op2 while using camera with flash?? when i m using my camera with flash my mobilescreen is suddenly off
  7. dr.karthik k
    same probelm with me
  8. dr.karthik k
    does anybody having probelm with op2 while using camera with flash?? when i m using my camera with flash my mobilescreen is suddenly off please anyone can help me
  9. lucifercipher
    Froyo Oct 22, 2015
    lucifercipher , Oct 22, 2015 :
    Updated via official OTA to OxygenOS 2.1.1 and man i tell you, the battery drain is a killer. Even phone standby drains battery faster. I can barely reach 3 hours of screen on time. Anyone can share their experiences?
  10. lucifercipher
    Froyo Oct 22, 2015
    Me too. Overall the battery usage went high and benchmarks went slightly lower. And it does run warmer now compared to before.
  11. lucifercipher
    Froyo Oct 22, 2015
    Same here. Phone runs warmer than before so i removed clash of clans and now play it on my Note 4 instead. I regret updating to OxygenOS 2.1.1 for two main reasons:
    1. Less battery time compared to previous update.
    2. Warmer than before.
    Nirav Mistry likes this.
  12. lalondesteve
    Froyo Oct 22, 2015
    johannt likes this.
  13. andyRyip
    Cupcake Oct 23, 2015
    andyRyip , Oct 23, 2015 :
    I recently uninstalled an app which was also on my Shelf prior to uninstalling.
    Now my Shelf is completely empty. It only displays the header picture and when I try adding
    previous boxes such as "Recent Contacts", it brings me to the multi tasking screen.
    Anyone run into this problem or have a solution?
  14. harshrthakkar
    Gingerbread Oct 23, 2015
    harshrthakkar , Oct 23, 2015 :
    UPDATE THE MESSENGER APP FROM GOOGLE PLAYSTORE ...TO SOLVE THE ISSUE.BATERY DRAIN IS A ISSUE AFTER UPDATE.
    OVER ALL OS IS CARBONDIOXIDE AS THE USER SIFFOCATES...I HVE BLISSPOP ITS UNBEATABLE...
  15. Dynal
    Cupcake Oct 24, 2015
    Dynal , Oct 24, 2015 :
    Sa
    Same
    Mine too
    dr.karthik k likes this.
  16. Dynal
    I'm facing many problems after I'll update os 2.1.1 ..Double tap not working perfectly and gestures to.. While capture a photo using flash suddenly screen off ...
    Is anyone having same problem here??
  17. sanjaymishra22
    Eclair Oct 24, 2015
    sanjaymishra22 , Oct 24, 2015 :
    You can try tapping home button twice to sleep or lock the fone. (Make sure you assign double tap on gesture control setting under settings).
  18. cleveland
    cleveland , Oct 24, 2015 :
    The camera app is complete trash. The image stabilization is terribly slowing buggy, plus it is super annoying having to go all the way into google photos to look delete photos after you take them. Should be able to integrate the photo gallery right into the camera app for a smooth transition. Currently have to use google camera for something that has a smooth interface, not buggy, and transitions well. Please Fix!!
    Also being able to adjust the media volume from the call volume rocker would be nice, instead of having to go into sounds and then adjust the media volume.
  19. jony.az
  20. drnaumaan
    Eclair Oct 25, 2015
    drnaumaan , Oct 25, 2015 :
    Hi @vinoth83 I'm talking about multi select in a conversation... Even I'm able to multi-select messages. And by the way, I posted in a wrong thread, I use OP2 and this section is for Oxygen OS for OPO.
