87
Oxygen OS Issues Thread
  1. Nancy Guha
    Cupcake Nov 17, 2015
    Nancy Guha , Nov 17, 2015 :
    Close all button suddenly disappeared one fine day. Oxygen OS version 2.1.2. Build number ONE A2003_14_151109. Any help is really appreciated as its annoying to close all one by one....
  2. hassan83
    hassan83 , Nov 17, 2015 :
    Reboot in safe mode (long press in the power menu). Once you're in safe mode, reboot again, that should do the trick. :D
  3. pjktheking
    Donut Nov 17, 2015
    pjktheking , Nov 17, 2015 :
    I'm confused, too.
  4. dotternetta
    Eclair Nov 18, 2015
    dotternetta , Nov 18, 2015 :
    Where is the wifi activity indicator in the wifi symbol? The up and down arrows are gone.
  5. advait17
    Cupcake Nov 19, 2015
    advait17 , Nov 19, 2015 :
    Facing a few issues since the upgrade to 2.1.2 :
    1. Battery indicator has vanished. Refer screenshot. had to install a third party widget
    to see the battery status.
    2. very often, audio output is without any bass. A reboot fixes it though.
    3. Fingerprint sensor accuracy has dropped considerably!
    4. Reduced screen on time
    Is anyone facing similar issues? Any suggestions?
  6. lokesh3440
    Honeycomb Nov 19, 2015
    lokesh3440 , Nov 19, 2015 :
    Please post in One plus 2 thread Buddy. Only then you will find appropriate answers.
    advait17 likes this.
  7. advait17
    Cupcake Nov 20, 2015
    advait17 , Nov 20, 2015 :
    Thanks. Didnt realise i was posting in the wrong place.
  8. Step.hen99
    Donut Nov 28, 2015
    Step.hen99 , Nov 28, 2015 :
    Hi guys i'm having problems installing the 2.1.2 update on my unrooted one plus two. I am currently running 2.1.0 and the system update is telling me to update to 2.1.2 but everytime i go to install it the phone goes to the install mode then the install fails and it gives me no option but to reboot the phone back to its original state.
    Any help would be extremely appreciated thanks
  9. tcblues
    Cupcake Nov 28, 2015
    tcblues , Nov 28, 2015 :
    I have oxygen 1 on my opo and the compass/gyroscope is not detected. When I start and app that needs gyroscope like for example LG magic remote-control, it says that any gyroscope is detected. I tried many apps and same problem. Any solution?
  10. tye359
    Ice Cream Sandwich Nov 30, 2015
    tye359 , Nov 30, 2015 :
    i have no idea why anyone would be running Oxygen on the 1+1 when cyanogen is so much better; not only that there are some excellent Marshmallow roms now available - currently running Sultan's Unofficial CM13 build.
  11. dabendra
    Gingerbread Dec 1, 2015
    dabendra , Dec 1, 2015 :
    Is oneplus even lisning to us. My oneplus 2 is working like shit now ,:mad:.We dont see any reply from them even after so many issues and complaints. :(:eek:
  12. arslanemre
    Eclair Dec 5, 2015
    arslanemre , Dec 5, 2015 :
    hi
    i have twrp on my oneplus x and i system wiped so i dont have a rom now
    now i cant install oxygenos again because it says E: Error executing updater binary in zip ' external_sd/oxygen_1.0.0_flashable.zip'
    please help me [​IMG]
  13. mixalhsxalk
    Cupcake Dec 5, 2015
    mixalhsxalk , Dec 5, 2015 :
    I think you should wipe everything and format data before flashing.
  14. arslanemre
    Eclair Dec 6, 2015
    arslanemre , Dec 6, 2015 :
    if i format data it says:
    flash_image footer,resize /dev/zero process ended with error=255
    ***RED***
  15. mixalhsxalk
    Cupcake Dec 6, 2015
    mixalhsxalk , Dec 6, 2015 :
    Are you sure that you ticked/checked everything in wipe session?Im not sure but i think you should 0)Unplug from your pc 1)Wipe everything(tick/check everything and format data if this is possible 2)reboot to recovery 3)If you cant format data before try it again now 4)reboot in recovery again 5)Plugin to pc and copy rom file to your sdcard/phone storage root 5)unplug from your pc and flash(if you cant flash it ' try a reboot to recovery without plugin it to pc)
    As i read in an article this error come from davlik -cache.Please do not restore phone after flashing.
  16. archaven
    Cupcake Dec 12, 2015
    archaven , Dec 12, 2015 :
    I'm loving this at the moment! At least this didnt have the restart fest of CM. Only thing i found is wifi seems a little slow.
  17. samirsadikhov
    Cupcake Dec 13, 2015
  18. Kumarn86
    Cupcake Dec 15, 2015
  19. ath.peppas
    Gingerbread Dec 22, 2015
    ath.peppas , Dec 22, 2015 :
    Since I have installed TWRP and UNROOTED STOCK 2.2.0 "amazon prime music" can't be installed, because its says its not compatible with my android version.
    Any solution ?
  20. ath.peppas
    Just installed through amazon marketplace app. But do you know whether I can install it the normal way ?
