87
Oxygen OS Issues Thread
  1. Guntux
    Cupcake Mar 23, 2017
    Guntux , Mar 23, 2017 :
    Oneplus one update nougat will never see the light. Go to Lineage OS. Or miracle an update on oneplus X (Nougat) and op portage on oneplus one
  2. umariyoob
    Donut Mar 27, 2017
    umariyoob , Mar 27, 2017 :
    Never heard of Lineage OS until now! Thanks for the update! I'm going to go that route now. I was busy with life until I realized that I wasn't getting any updates!
  3. Levi.K
    Cupcake Mar 30, 2017
    Levi.K , Mar 30, 2017 :
    So I want to flash my OPO with Oxygen OS what should I use to back-up my phone?
  4. soso882
    Cupcake May 11, 2017
  5. j4v3d
    Gingerbread Jun 9, 2017
    j4v3d , Jun 9, 2017 :
    Think i'll stick with CM for now.
  6. CynicalScot
    Cupcake Jun 12, 2017
    CynicalScot , Jun 12, 2017 :
    Began to install OxygenOS as to the instructions found here and after using command 4 in allinone.bat my phone now no longer does anything except buzz when holding the power or power+volume up/down for a few seconds, and it is not recognized by my computer.
  7. sua6875
    Cupcake Jun 13, 2017
  8. iamjestonilee
    Eclair Jun 21, 2017
  9. sandorm54
    Cupcake Aug 28, 2018
    sandorm54 , Aug 28, 2018 :
    Bro if you are facing in-app purchases I would recommend you download the freedom app to bypass all the purchases for free. You can also use freedom app on windows device using blue-stacks emulator
  10. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Aug 28, 2018
    KeepTransisting , Aug 28, 2018 :
    Dude was facing in app purchases three years ago.....
  11. sandorm54
    Cupcake Sep 12, 2018
    sandorm54 , Sep 12, 2018 :
    Not only freedom app but there also other apps like freedom that will help you out in doing in-app purchase
  12. DeluxeNoone
    Ice Cream Sandwich Sep 19, 2018
  13. K1543243174400
    Cupcake Nov 26, 2018
  14. S1542047665474
    S1542047665474 , Nov 26, 2018 :
    Can't open apps. Some apps are misbehaving when I updated my one plus one from synogen is to oxygen is. Apps are crashing including phone and message app. Help me for this problem
  15. thebarber
    Gingerbread Nov 26, 2018
    thebarber , Nov 26, 2018 :
    use lineage 15.1 much more stable on the 1+1
  16. S1542047665474
  17. thebarber
    I get updates daily , just Google it easy to find
  18. S1542047665474
  19. thebarber
    one plus boot logo , then lineage , and your ready to rock , there is a lineage 16.1 but unstable , stick to 15.1
  20. S1542047665474
