732
Oxygen OS Open Beta 1 for the OnePlus 6
  1. V1P_J0K3R
    Gingerbread Sep 3, 2018
    Vladut123 likes this.
  2. J1535518237687
    Froyo Sep 3, 2018
    J1535518237687 , Sep 3, 2018 :
    your zip file might not have been downloaded completely then...make sure you download the correct rom also
  3. BhavyaMehta0786
    Ice Cream Sandwich Sep 3, 2018
    BhavyaMehta0786 , Sep 3, 2018 :
    it is still there if you are referring to the the %battery left to be shown in the status bar
  4. F_Hersh_Shah_fqmw
    Froyo Sep 3, 2018
    F_Hersh_Shah_fqmw , Sep 3, 2018 :
    I have same question? Did you find something?
  5. abhay3418
    Froyo Sep 3, 2018
    abhay3418 , Sep 3, 2018 :
    Any know about this?
  6. abhay3418
    Froyo Sep 3, 2018
    No..
  7. XRaptor29
    XRaptor29 , Sep 3, 2018 :
    It's there. Settings > Display > Status bar > Show battery percentage.
  8. V1P_J0K3R
    V1P_J0K3R , Sep 3, 2018 :
    i dont want to push the notification center down to show the % of my battery.
    i have this settings before that it always shows the % on homescreen or lock screen
  9. G_Arnab_Roy_eFPy
    Eclair Sep 3, 2018
    G_Arnab_Roy_eFPy , Sep 3, 2018 :
    other problem. swiping down the notification panel. you have pull all the way upto the half of the screen to see the notification panel.
    a smaller swipe doesn't bring the panel. hydrogen os beta 1 hade the same problem. they fixed it in the beta 2
  10. F_Hersh_Shah_fqmw
    Froyo Sep 3, 2018
  11. BhavyaMehta0786
    yes it still does
    settings>display>status bar>battery percentage
  12. V1P_J0K3R
    oh i see there some confuse description in German.
    i just search it on the style menu
  13. BhavyaMehta0786
    no it does open up even if I just open the notification panel about a centimetre down from the notch
  14. amritpal2489
    Eclair Sep 3, 2018
    amritpal2489 , Sep 3, 2018 :
    finally... ate the pie.. i can confirm both dual 4g and volte works fine.. its jst d symbol which on oreo used to show volte with 1 2 up n below now only shows one no. for which data is active
  15. G_Arnab_Roy_eFPy
    Eclair Sep 3, 2018
    for me i have to full upto the half of the screen
  16. cryofreezepie
    Froyo Sep 3, 2018
    cryofreezepie , Sep 3, 2018 :
    I downloaded the one directly from this page or page 1. I will try to redownload
    Vladut123 and J1535518237687 like this.
  17. BhavyaMehta0786
    I don't think such a problem should exist... this could rather be a user to user difference of the technique
  18. G_Arnab_Roy_eFPy
    Eclair Sep 3, 2018
    try to select other sim than jio for data. dual 4g will disappear
  19. Ashwin222221
    Froyo Sep 3, 2018
    Ashwin222221 , Sep 3, 2018 :
    I have already installed this and it's smooth only few scrolling lags on webpages but it's ok rest all working fine even play store is working fine no problem at all till now let's see
  20. amritpal2489
    Eclair Sep 3, 2018
    tried already... works for me
