732
Oxygen OS Open Beta 1 for the OnePlus 6
  1. Gav_W86
    Moderator Moderator Sep 3, 2018
    Gav_W86 , Sep 3, 2018 :
    eta? do you mean ota?
    you won't automatically get stable build, you will need to wipe and reflash (as it says in opening post).
    Vladut123 likes this.
  2. Gowrishkaran
    Donut Sep 3, 2018
  3. F_Hersh_Shah_fqmw
    Froyo Sep 3, 2018
    F_Hersh_Shah_fqmw , Sep 3, 2018 :
    But I will get beta Ota right?
  4. Gav_W86
    as it says in the opening post, to return to stable you will need to wipe and reflash to a recovery ROM.
  5. tosun97
    Gingerbread Sep 3, 2018
    tosun97 , Sep 3, 2018 :
    Quite amazed by the battery life so far. Charged it intentionally to 100% just to check how bad the drain and overall battery would be.
  6. utsav17
    Honeycomb Sep 3, 2018
    Vladut123 and hoggar10 like this.
  7. Gav_W86
  8. hoggar10
    hoggar10 , Sep 3, 2018 :
    haha, I'm not sure, thought it was a little weird as it's on the right on my Pixel 2
  9. Gav_W86
    delayed by one day for every person who posts asking for it.
    androide13 and Vladut123 like this.
  10. utsav17
    utsav17 , Sep 3, 2018 :
    so they are just trying to be different?
    where is that "when your friend tries to copy your homework but makes little change" meme
  11. Winsten
    Cupcake Sep 3, 2018
  12. Gav_W86
    it is a beta test build. there may be issues. suggest you just stay on stable build until it is released as a full stable build.
  13. lutti
    KitKat Sep 3, 2018
    lutti , Sep 3, 2018 :
    I'm sorry to possibly repeat a question but there are currently 48 pages of this so i'm not going to go through all of that.
    So the question is is this version going to get the next updates OTA?
    Oh and is this update going to loose all my settings etc?
  14. robmoh
    Eclair Sep 3, 2018
    robmoh , Sep 3, 2018 :
    because volume buttons are on the left.
    DogeAlpha and Vladut123 like this.
  15. Gav_W86
    no. its a test release. there will likely be another release post like this with a new build at some point which you can download and flash in the same way. And if you want to go back to stable builds you will need to wipe and reflash to a recovery ROM. Suggest if you want OTA updates you just wait until the full stable release is pushed.
    Vladut123 and Gowrishkaran like this.
  16. Gowrishkaran
    Donut Sep 3, 2018
    Gowrishkaran , Sep 3, 2018 :
    Thanks buddy [e]1f60a[/e]
  17. Palmo23
    Donut Sep 3, 2018
    Palmo23 , Sep 3, 2018 :
    This is probably asked plenty of times but has anyone messed around with the beta and think that it's stable enough for others to download? I know there are currently issues with it but with everything else is it running flawlessly? Also when stable pie comes out, I assume I have to download the OTA and flash it myself and that it will wipe my data?
  18. Pt25
    Eclair Sep 3, 2018
    Pt25 , Sep 3, 2018 :
    i downloaded Oxygen OS Open Beta 1 .. but it's show's nothing in Local upgrade section
  19. TonioLA
    Ice Cream Sandwich Sep 3, 2018
    TonioLA , Sep 3, 2018 :
    how did you get this Google widget style ?third party launcher ?
  20. Palmo23
    Donut Sep 3, 2018
    I read in comments that you need to put it from downloads to internal storage
