849
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. docnok63
    Jelly Bean Sep 4, 2019
    docnok63 , Sep 4, 2019 :
    Since everything else looks right, the only thing I can suggest is using the Oxygen Updater app from the Play Store. Go into Settings and change upgrade option to Android 10 Developer Preview (I think that they've done OB now...not sure. Already on it so can't see.)
    Magndut likes this.
  2. T1563217588506
    Cupcake Sep 4, 2019
  3. akks
  4. vinu703
    Cupcake Sep 4, 2019
    vinu703 , Sep 4, 2019 :
    I am unable to find navigation buttonswap option, face unlock feature and oneplus switch with the latest update.
    I am using oneplus 7. can
    anyone help me what could be wrong?
  5. docnok63
    That's all ugly. I'd recommend a factory reset
  6. G_vennavalli_ashok_rstl
    Gingerbread Sep 4, 2019
  7. vinu703
    Cupcake Sep 4, 2019
    I will try.i am not rooted and followed the procedures mentioned in thread.
  8. slfisher
    Cupcake Sep 4, 2019
    slfisher , Sep 4, 2019 :
    I don't know what you mean by " select the internal storage." This is what I see,:
  9. snabb
    Honeycomb Sep 4, 2019
    snabb , Sep 4, 2019 :
    Can someone explain to me how could I use almost 29gb in section "others" when I just installed apps and copied my media files to my new phone?
    It's happen after I upgraded to Beta 1.
    Is anyone facing same issue?
  10. LRNZ09
    Cupcake Sep 4, 2019
  11. amiydwivedi
    Donut Sep 4, 2019
    amiydwivedi , Sep 4, 2019 :
    on one hand you are saying update from MP - OBT will not erase the user data but in the installation process it clearly says system will boot in recovery mode and user data will be wiped out??? Kindly clarify will the data be erased or not???
  12. Dgafking0480
    Ice Cream Sandwich Sep 4, 2019
    Dgafking0480 , Sep 4, 2019 :
    screen shot?
  13. Dgafking0480
    could be the operating system itself
  14. idbl_fanatic1
    idbl_fanatic1 , Sep 4, 2019 :
    No disrespect here, but if you don't know how to move a file, I would suggest that you just wait for the OTA
    muharrem1961 and Petzkub like this.
  15. G1566192149155
    Cupcake Sep 4, 2019
  16. Himalaya Dave
    Himalaya Dave , Sep 4, 2019 :
    It's About Time For A New And Modern Boot Animation ! Which Reflects Oxygen OS And Android's New Design Language And Colors .A Few More Fonts Would Be Appreciated .Try Giving An Option Of Default Stock Android Theme Too .
    The OnePlus Launcher Can Also Be Overhauled Like The Newer Pixel Launchers Or Launchers Like Lawnchair Alpha .
    Ken_Brownstone and Huigiebaby like this.
  17. snabb
    Well, then it's bigger than windows 10 system [e]1f601[/e]
  18. docnok63
    Go into Settings\System\Reset options and choose bottom option
    You have the file in downloads folder. Cut and paste it to internal storage
    Try clicking on it to delete whatever files you don't want from it.
    MP to OBT will not erase data the first time you do it. All other times will do it. OBT to MP will always wipe.
    amiydwivedi likes this.
  19. snabb
    +1
    Also Ambient display (pick up your phone to show) comparing to Android 9 does not work so well.
    Huigiebaby likes this.
  20. bigdirtypj
    Cupcake Sep 4, 2019
    bigdirtypj , Sep 4, 2019 :
    Warning. Do not install this if you have the TMobile version of this phone with the international firmware installed. if your phone is network locked, it will disable your sim card. I just tried it and had to downgrade
