849
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. hemanth_mudra
    Gingerbread Sep 4, 2019
    hemanth_mudra , Sep 4, 2019 :
    The changelog isn't present but it should pretty much start the installation progress. please wait for it to start.
  2. darkn3xx
    Donut Sep 4, 2019
  3. hemanth_mudra
  4. B_VEERENDRA11
    Donut Sep 4, 2019
  5. KawaiiGuy17
    Eclair Sep 4, 2019
    KawaiiGuy17 , Sep 4, 2019 :
    Found a problem with a black bar appearing at the bottom of the keyboard... it's honestly annoying lol
  6. Agnishchakra
    Cupcake Sep 4, 2019
    Agnishchakra , Sep 4, 2019 :
    K20 pro got the stable virson of android 10 on the same day. Funny?
  7. X1567623277793
    Cupcake Sep 4, 2019
  8. Soulreaper666
    Cupcake Sep 4, 2019
  9. hemanth_mudra
    In a few weeks I guess. The OBT is almost flawless. It is actually good. Give it a shot.
  10. docnok63
    Jelly Bean Sep 4, 2019
    docnok63 , Sep 4, 2019 :
    I don't even have an "Others" under my storage
    If you can not access the files in questions, then I suggest a complete factory reset (bottom option in Settings\System\Reset optoins)
    1) Root via Magisk is the only way to load modules and, as an audiophile, I must have Viper4Android on my phone.
    As I also posted here or in the DP threads, I use two modules to fix ctsProfile issues.
    2) TWRP is the best backup available that I know of. OnePlus Switch backup doesn't save your login info to apps, so on a restore, you must manually set up each app....pain in the a$$. TWRP saves all of that. I have seen people talk about Google Backup here, but I've never used it and apparently it's broken in OB1
    3) If something goes really wrong on your phone and it looks unrecoverable, 99% of the time it's recoverable because you have unlocked bootloader and can fastboot install something or MSMtool. There's rarely a way you can't recover with all options open.
    I was having trouble flashing OB1 from DP5 with similar error message. 9.5.11 with v52 TWRP worked for me. Perhaps flash TWRP v40?
    There's no way for average Joe's like us would know OnePlus' development intentions. Please use the feedback links at the bottom of the first post to let them know your feelings on the matter.
  11. hemanth_mudra
    Upload some screenshots of possible.
  12. KawaiiGuy17
    Eclair Sep 4, 2019
  13. hemanth_mudra
    Yes Miui is a joke!
  14. hemanth_mudra
  15. Cocco2
    Donut Sep 4, 2019
    Cocco2 , Sep 4, 2019 :
    When in landscape mode while gaming if i use gestures It won't go back to full screen, It keeps showing the nav bar below everything...See the screenshot...
  16. jhnwlkr
    Froyo Sep 4, 2019
  17. KawaiiGuy17
    Eclair Sep 4, 2019
    nope, tried and didn't work
  18. G_android_x14
    G_android_x14 , Sep 4, 2019 :
    How is anyone "being treated like trash"? are they being tied up in plastic bags and being dumped in a big piles? I missed that.
    iampun33t and S1558269980867 like this.
  19. hemanth_mudra
    Oh yes I forgot. The black bar holds the navbar and also an arrow-down on the left to hide the keyboard. See the screenshot.
  20. snabb
    Honeycomb Sep 4, 2019
    snabb , Sep 4, 2019 :
    Did you try through file manager? There you will be able to see section "others".
