875
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. Mahesh_Uma
    Cupcake Sep 5, 2019
    Mahesh_Uma , Sep 5, 2019 :
    got it [e]1f44d[/e] thanks !
    Dgafking0480 likes this.
  2. F_Tejaswi_Tingi_bkVl
    Eclair Sep 5, 2019
    F_Tejaswi_Tingi_bkVl , Sep 5, 2019 :
    If you are on Open Beta already, just go to settings and search for reset.
    Once you start reset you are given the option to keep or delete data.
    You can decide to keep data but the reset will delete all your apps and settings.
    Once complete, the normal android setup will start and you can set everything up from scratch and install all apps.
  3. beings@m
    Cupcake Sep 5, 2019
    beings@m , Sep 5, 2019 :
    you have to update via oxygen Updater but first you have to download the file provided in the post above
  4. Maverick2.0
    KitKat Sep 5, 2019
    Maverick2.0 , Sep 5, 2019 :
    Why don't you learn to read in context? Not my problem of you can't.
  5. H1561960043803
    Ice Cream Sandwich Sep 5, 2019
    H1561960043803 , Sep 5, 2019 :
    follow the instructions on the first post
  6. mcook4706
    Donut Sep 5, 2019
    mcook4706 , Sep 5, 2019 :
    Has anyone else experienced lagging in the keyboard while typing after the update. Also, scrolling speeds slowed after update and it's going slower now with 90Hz then it did with 60 before the update.
  7. ShermCraig
    Honeycomb Sep 5, 2019
    ShermCraig , Sep 5, 2019 :
    Lol, okay Maverick.
  8. P1567479136446
    Cupcake Sep 5, 2019
  9. F_Alok_Srivastava_Qulf
    Cupcake Sep 5, 2019
  10. CK马克兔
    Cupcake Sep 5, 2019
  11. Sunilsudha
    Froyo Sep 5, 2019
  12. Cervantes
    Moderator Moderator Sep 5, 2019
    Cervantes , Sep 5, 2019 :
    Hi
    Please You read the first post
    The beta or update thread is a thread of questions and/or commentary
    Thread merged
  13. VanleabK
    Froyo Sep 5, 2019
    VanleabK , Sep 5, 2019 :
    after install beta 1, i got this "hey google" in google search widget. how can i disable it? thanks
  14. NickMidd91
    Gingerbread Sep 5, 2019
    NickMidd91 , Sep 5, 2019 :
    you have to install the man flash international file then update your phone to 9.5.11 then download the open beta 1 then install it then your done
    Krendro likes this.
  15. Abhik2580
    Eclair Sep 5, 2019
    Abhik2580 , Sep 5, 2019 :
    will it erase the data on my internal storage when upgrading from pie to open beta on OnePlus 7?
    F1522470942433 and rayprayas like this.
  16. Dgafking0480
    Dgafking0480 , Sep 5, 2019 :
    but if he isn't sim unlocked he won't have service unless OnePlus releases the official stable version soon
  17. rayprayas03
    rayprayas03 , Sep 5, 2019 :
    if i update my phone will it erase my data?? is there is bugs and something kind of thing present in this update????
    PLEASE LET ME KNOW
    Abhik2580 likes this.
  18. NickMidd91
    not true I did it before getting sim unlocked and got service on TMobile
  19. NickMidd91
    updating you will not loose anything at all
  20. Rohan28Handa
    Cupcake Sep 5, 2019
    Rohan28Handa , Sep 5, 2019 :
    I have a OnePlus 7 Pro 12 GB ram edition. After the update the system performance has deteriorated.
    The major problem I've experienced after this update is that the phone had automatically reset to factory settings. If by any chance I didn't have my data backed up then I would be dead lmao. Also one of the live wallpaper (the blue one) has strange water bloom affect on the lower left side of the home screen which disappears as we open the app shelf. The display is not so smooth as well. Hope these get fixed..... great work though[e]1f44d[/e][e]1f44d[/e][e]1f44d[/e]
