837
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. NickMidd91
    Gingerbread Sep 5, 2019
    NickMidd91 , Sep 5, 2019 :
    updating you will not loose anything at all
  2. Rohan28Handa
    Cupcake Sep 5, 2019
    Rohan28Handa , Sep 5, 2019 :
    I have a OnePlus 7 Pro 12 GB ram edition. After the update the system performance has deteriorated.
    The major problem I've experienced after this update is that the phone had automatically reset to factory settings. If by any chance I didn't have my data backed up then I would be dead lmao. Also one of the live wallpaper (the blue one) has strange water bloom affect on the lower left side of the home screen which disappears as we open the app shelf. The display is not so smooth as well. Hope these get fixed..... great work though[e]1f44d[/e][e]1f44d[/e][e]1f44d[/e]
  3. Dgafking0480
    Ice Cream Sandwich Sep 5, 2019
    Dgafking0480 , Sep 5, 2019 :
    if he's wanting Android 10 it is true many people have reported no service after flashing the open beta at least on the 7 pro
  4. J1566325663834
    Cupcake Sep 5, 2019
    J1566325663834 , Sep 5, 2019 :
    The Google keyboard is not at the bottom of the screen, it's a little bit higher
    And there is still no aod
    Sibiarasu likes this.
  5. Rohan28Handa
    Cupcake Sep 5, 2019
    I lost mine[e]1f62d[/e]. Please back up Ur data and then update.
  6. O1567648453084
    Cupcake Sep 5, 2019
  7. NickMidd91
    well I have used Android q dp and oppen beta 1 with no problems with signal
  8. rayprayas
    Froyo Sep 5, 2019
    rayprayas , Sep 5, 2019 :
    i haven't use beta version earlier are you sure pal it's gonna be my first update and I'm using oneplus 7 ..
    is there any bugs
  9. V1559893938206
    Cupcake Sep 5, 2019
  10. Dgafking0480
    no not yet
  11. Dgafking0480
    it's a beta version there will always be bugs
  12. NickMidd91
    no its not but you can still install it over 9.5.11 if you flash it threw the TMobile to international msm file on your computer
    Dgafking0480 likes this.
  13. NickMidd91
    yes that say no data lose and I flashed this over 9.5.11 with all my date
  14. R1549992691618
    Cupcake Sep 5, 2019
    R1549992691618 , Sep 5, 2019 :
    I have the T-Mobile OnePlus 7 Pro model that is capable of getting international firmware updates, etc. I installed the Android 10 Open Beta 1 update and it SIM locked my phone. So I had to rollback to the stable version. I did everything I could think of to keep the beta version but I couldn't make a call.
    Any idea on how to fix this issue?
  15. rayprayas
    Froyo Sep 5, 2019
    what's your opinion pal? should i update it??
    im bit confused about this decision...
    or should i wait for stable release????
  16. C1560391368286
    Eclair Sep 5, 2019
  17. Dgafking0480
    your phone needs to be sim unlocked for you to be able to have service and make calls. there is a post on xda that can help you get your phone sim unlocked, I had the same issue with DP 5 I actually contacted TMobile and got mine sim unlocked permanently by sheer luck I believe anyway
  18. Dgafking0480
    I updated to the beta version the bugs I've noticed I can deal with honestly. it's your choice on if you flash it or not I can't tell you to do it or not to do it
  19. rayprayas
    Froyo Sep 5, 2019
    ok bro. any idea when we gonna get official OTA update?
  20. Cervantes
    Lollipop Moderator Sep 5, 2019
    Cervantes , Sep 5, 2019 :
    Hi
    Please You read the first post
    The beta or update thread is a thread of questions and/or commentary
    Thread merged
