836
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. raviteja_naidu
    Eclair Sep 5, 2019
    raviteja_naidu , Sep 5, 2019 :
    i installed android Q, but i wanted to roll back to the pie in that it will be any data loss ??
  2. The_Rock90
    Jelly Bean Sep 5, 2019
    The_Rock90 , Sep 5, 2019 :
    yes in that definitely
  3. W1565498560490
    Donut Sep 5, 2019
    W1565498560490 , Sep 5, 2019 :
    Yeah of course it's been discussed already but I'm just tired to see if dumb comments asking for the update , begging to get the update the same day as OP7 when your device is from last gen.
    Oh and I don't care about the ranking system here in the forums, that's not even relevant.
  4. U1565290756817
    Cupcake Sep 5, 2019
    U1565290756817 , Sep 5, 2019 :
    When can we expect the stable build?
    And now that I'm running my One plus 7 pro on Public beta build, how will I be able to update to stable build? By normal official updates or downloading the package and then updating from Root directory?
    Also, will there be any repercussions of data loss during the same?
    charan365 likes this.
  5. E1566281129491
    Cupcake Sep 5, 2019
    E1566281129491 , Sep 5, 2019 :
    after rollback to stable version, I find that the phone is getting warn or heat up so so quickly, even in the normal usage of 5-10 mins
  6. KONDODDI Hemareddy
    Donut Sep 5, 2019
  7. raviteja_naidu
    Eclair Sep 5, 2019
  8. Jeramy_Koval
    Froyo Sep 5, 2019
    Jeramy_Koval , Sep 5, 2019 :
    No, I was at the latest Android pie build and upgraded via the local install procedure. I did perform a backup via Google though prior to the upgrade.
  9. J1566325663834
    Cupcake Sep 5, 2019
    J1566325663834 , Sep 5, 2019 :
    When the stable version comes out, will we need to install it manually or will it install automatically?
  10. sia_0
    Froyo Sep 5, 2019
    sia_0 , Sep 5, 2019 :
    It will boot with Android Q. If you want to rollback, check the first page
  11. Maverick2.0
    KitKat Sep 5, 2019
    Maverick2.0 , Sep 5, 2019 :
    You are dumber then I thought. No point engaging you.
  12. Stylianos_Kalintzis
    Froyo Sep 5, 2019
    Stylianos_Kalintzis , Sep 5, 2019 :
    Good morning!
    After 12 hours with BETA in this morning I decided to do hard reset. The phone now works even better than yesterday, now I am getting notifications and Gmails, also the lockscreen now shows the time and face unlock is working.
    No issues so far. Therefore I strongly recommend to do hard reset after installation.
    Dgafking0480 likes this.
  13. W1565498560490
    Donut Sep 5, 2019
    lol move us @ss back to to Ur 6/6T forums
  14. v.suresh_Kumar
    Cupcake Sep 5, 2019
    v.suresh_Kumar , Sep 5, 2019 :
    after all the rumour has confirmed but after updating to Android Q beta BANKING APP'S not working
    Ravitejanayudu likes this.
  15. Dgafking0480
    Ice Cream Sandwich Sep 5, 2019
    Dgafking0480 , Sep 5, 2019 :
    mine works just fine
  16. Petzkub
    Froyo Sep 5, 2019
    Petzkub , Sep 5, 2019 :
    People, plz.
    1. Read the OP. And then read it again.
    2.Use search, your question has been asked and answered 100 times already.
    3. If you have a question is about any other device than the OP7 / OP7 Pro, you are in wrong thread.
    And calm down. The beta was just released. Dont ask ETAs for stable release. If there is info about upcoming releases, I think youll find the info about that in the op-forums via search. If not, there is no info about next release.
    jim.kanaris and Dgafking0480 like this.
  17. docnok63
    docnok63 , Sep 5, 2019 :
    Welcome to the forums! Please read the bottom of the first post to provide feedback to OnePlus
    You have to give Contacts app all permissions it asks for (in this case storage)
    You have to be SIM unlocked from TMo in order to run OB1. If your device isn't paid off, use the XDA thread to fix that situation
    Hold Power + Volume Up for 10 seconds to reboot. Profit
    OB1 didn't SIM lock your phone. OnePlus did as they were contractually obligated to do to send phones to TMobile. Use XDA thread to SIM unlock your phone. You can get data through WiFi
    Everything looks right. Do you have 5G variant? If so, not compatible.
    3-6 weeks, install will be just like first post and you will 100% lose data by going to stable
  18. vinu703
    Cupcake Sep 5, 2019
    vinu703 , Sep 5, 2019 :
    docnok63
    j hi
    3-6 weeks, install will be just like first post and you will 100% lose data by going to stable​
  19. vinu703
    Cupcake Sep 5, 2019
    It is not a 5g variant. I am facing the sam issue while going back to Android pie.
    should I root my mobile for this?
  20. shaleen9296
    Cupcake Sep 5, 2019
