826
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. G1567093991582
    Cupcake Sep 6, 2019
  2. b3nji_s0_0s
    Froyo Sep 6, 2019
    b3nji_s0_0s , Sep 6, 2019 :
    Here's my feedback, I wasn't able to post it as it was wayyy too long but yeah... there you go.
  3. G1567093991582
    Cupcake Sep 6, 2019
  4. Tareksleem
    Cupcake Sep 6, 2019
    Tareksleem , Sep 6, 2019 :
    After updating to Android 10 for OnePlus 7 pro battery drain too fast without any consumption
  5. Cervantes
    Lollipop Moderator Sep 6, 2019
    Cervantes , Sep 6, 2019 :
    Hi
    Please You read the first post
    The beta or update thread is a thread of questions and/or commentary
    Thread merged
  6. Ayush1425
    Cupcake Sep 6, 2019
    Ayush1425 , Sep 6, 2019 :
    very stable to be honest.
    the overall experience is definitely an upgrade.
    system wide dark theme is good.
    only issues-
    1. the unlock screen freezes on double tap to wake, while it works fine on pressing unlock button and then unlocking.
    2. hotstar app misbehaves.
    3. the swipe gestures sometimes do not work in landscape orientation.
    4. screen heating issues.
    requests-
    1. add timed msg functionality to sms app.
    2. fix screen heating issues.
    3. add more wallpaper options via shot on one plus like daily change according to a selection of categories.
  7. Joehan_1303
    Cupcake Sep 6, 2019
    Joehan_1303 , Sep 6, 2019 :
    Did you try holding down the volume up + volume down and power button for some time , it should restart the phone and it should be resolved. I had the same problem and it worked for me.
  8. Bombei
    Eclair Sep 6, 2019
  9. G_Parth_V_Square_UXxZ
    Eclair Sep 6, 2019
    G_Parth_V_Square_UXxZ , Sep 6, 2019 :
    2 features missing so far
    1st not able to adjust the back gesture sensitivity
    2nd not able to get auto rotate thing to pop up while using full screen gesture
    the_reckoner likes this.
  10. Dr. Gaurav Rajput
    Donut Sep 6, 2019
    Ayush1425 likes this.
  11. T1528657491058
    Cupcake Sep 6, 2019
    T1528657491058 , Sep 6, 2019 :
    Ty man youre a life saver
  12. Dr. Gaurav Rajput
    Donut Sep 6, 2019
  13. my_thug_life
    Cupcake Sep 6, 2019
    my_thug_life , Sep 6, 2019 :
    really??
  14. docnok63
    Ice Cream Sandwich Sep 6, 2019
    docnok63 , Sep 6, 2019 :
    I agree that this feature should be optional. You can remove that NFL app by opening Game Space, longpress the NFL app's icon and select remove. I have removed all my games this way and none of them have come back once updated. My other solution was just to delete Game Space via root.
  15. c3drik67
    Froyo Sep 6, 2019
    c3drik67 , Sep 6, 2019 :
    for you? Never, because you don't read few page before your question.
    JmcRepair33 likes this.
  16. docnok63
    Originally posted by @iampun33t and modified by me, I guess this needs to be reposted every 1/2 hour or so:
    1. This is OOS Open Beta 1. It is based on final Android 10 from Google.
    2. There is no release date for stable version. We are guessing 3-6 weeks.
    3. This is only for OnePlus 7 and 7 Pro. It will not work on the 5G Model. T-Mobile customers will need their SIM unlocked or they won't have cellular data after installing OB1. If you just want to test, WiFi will work.
    4. Installing Open Beta from stable will not wipe your data.
    5. Rolling back to stable from Beta WILL wipe your data.
    6. Stable 9.5.11 will not get an OTA for this build. You need to download the Open Beta installer and install it via local update. If you're on T-Mobile firmware, you will not have a local update option. You will need to install international firmware first or use TWRP to install.
    7. The downloaded file needs to be in the root of the internal storage (moved from Download directory and top of internal and not in any folder)
    8. If your downloaded file has a .jar extension then rename it and remove the .jar part. The file needs to be in .zip extension to work. Do not unzip this file. If you are having installation problems, post a screenshot of current file location so we can help you.
    9. The Open Beta will not get the Stable update. It will get Open Beta updates even after Stable is released.
    10. As this is an Open Beta, it has some known and unknown bugs. Some banking apps will not work. Be ready for it.
    11. The list of bugs and features and all instructions and download link is in the First Post of this thread. Read it.
    12. If at any time you have Qualcomm Crash Dump mode, hold the power and volume up key for 10 seconds. Phone will reboot automatically and you'll be fine. This is a known bug.
    13. People are experiencing excessive battery drain with OB1. This is a bug with Google Play Services (just look at its drainage in battery settings) and is happening with other phone models as well. This needs to be fixed by Google and is not an OB1 bug.
    14. Feedback/bug reports in this thread are welcome, but also use the links at the bottom of the first post to ensure that OnePlus sees your input.
    15. As thread title says, this Open Beta is for OnePlus 7 and 7 Pro. Do not ask for update information for OnePlus 3/3T/5/5T/6/6T.
    More info about Open Beta Program from Head of User Experience Design:
    https://forums.oneplus.com/threads/oxygenos-beta-program-explained.469761/
    HZ_ND likes this.
  17. sagnik22@gmail.c
    Cupcake Sep 6, 2019
    sagnik22@gmail.c , Sep 6, 2019 :
    I think there are issues with Proximity sensor and Ambient Display.. sometimes proximity sensor doesn't goes off and Ambient Display doesn't lights up if the phone is picked up
  18. JmcRepair33
    Honeycomb Sep 6, 2019
    JmcRepair33 , Sep 6, 2019 :
    Cool Story Bro. thanks For the feedback, we always appreciate it everything helps
    K1567062453702 likes this.
  19. I1563005240970
    Cupcake Sep 6, 2019
    I1563005240970 , Sep 6, 2019 :
    Hi Team,
    My issue has been resolved automatically after I reboot my phone. Thanks for this update. If you can add CRT screen off animation in your next release that would be great like the cherry on the cake,,, my best wishes to you, keep doing the good work,,,CHEERS
  20. JmcRepair33
    JAJAJAJ that was a good on lol but its true. thats a really obvious question that people ask all the time just read not even 10 pages back and im sure you will find that question again and answered for like the 100th time
    c3drik67 likes this.
