872
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. Fauert
    Honeycomb Sep 3, 2019
    Fauert , Sep 3, 2019 :
    Working fine ! No problems ...
  2. JorgeMaTeixeira
    Gingerbread Sep 3, 2019
  3. Anatoly_2016
    Cupcake Sep 3, 2019
  4. sokhangoo
    Eclair Sep 3, 2019
    sokhangoo , Sep 3, 2019 :
    If I install the OB1, will I still receive OTA update when the stable version becomes available?
  5. Ayato27
    Cupcake Sep 3, 2019
  6. nipuna001
    Eclair Sep 3, 2019
    nipuna001 , Sep 3, 2019 :
    Not really, but I've force desktop, resize, and enable freeform windows on under developer options.
    then again, I must say it output fine even under Pie. the difference is that the desktop mode option and KB/Mouse recognition works now! :)
    Could also be an issue with the cable/hardware you use to link up?
  7. YauhenK
    Donut Sep 3, 2019
    YauhenK , Sep 3, 2019 :
    A lot of buzzing, messages, excitement... I also installed beta. But, actually, we got nothing new. Everything is absolutely the same as on 9. Gestures and digital wellbeing for the whole new version? Wow.
  8. B3nnyb0y1990
    Cupcake Sep 3, 2019
    B3nnyb0y1990 , Sep 3, 2019 :
    Loving this ob1. Everything is so smooth so far. Only issue I have which I always have on OOS but not on custom ROMs is there is no option to turn of Volte. I've tried the *#800# thing that was mentioned before but still no luck. I need to turn off Volte because where I live the signal isn't the best so every time my signal drops a bit the other person can't hear me on the phone and I end up having to hang up every phone call. If anyone can help with this that would be amazing.
  9. ric_vdl
    Cupcake Sep 3, 2019
    ric_vdl , Sep 3, 2019 :
    Hi. Just installed the open beta 1 on my Oneplus 7 Pro. Can't share photos on gallery. The phone tell me "Android System has stopped". Just performed a full wipe, but no changes... Has DP5 and It was working
  10. mysliwiec_tech
    Eclair Sep 3, 2019
    mysliwiec_tech , Sep 3, 2019 :
    On Pie it was exactly the same... I would also blame the hub/cable, but when I tried to connect my friend's Samsung Dex all was fine. I think I got to do more testing. Thanks for your quick reply!
    nipuna001 likes this.
  11. Phillyslix
    Phillyslix , Sep 3, 2019 :
    OB1 is what caused the issue. I can use everything but unable to make phone calls.
  12. Dbarnes0486
    Cupcake Sep 3, 2019
    Dbarnes0486 , Sep 3, 2019 :
    does anyone have the T-Mobile OnePlus 7 pro and if so were you able to install the open beta on your phone? and how. I've tried the steps and the T-Mobile version doesn't give you the same system > update manual option. I've also tried the boot into recovery mode and that doesn't have the same update method I've seen on Samsung devices. any help would be appreciated thank in advance..
  13. Fmps1987
    Fmps1987 , Sep 3, 2019 :
    First impression, is very fast.
    love the câmera
    bugs
    touchs on sides i think are not 100%
    keyboard have big space on buttom
    some gost Animations when use the home screen gesture
    O1566846095191 likes this.
  14. Wayne3333
    Cupcake Sep 3, 2019
    Wayne3333 , Sep 3, 2019 :
    hi guys, now I'm using the pie version so if I just install the stable version of android10 ist will erase my phone all data?
  15. Mukuljj
    Eclair Sep 3, 2019
    Mukuljj , Sep 3, 2019 :
    i am on dp5 still not got the beta updte.anyone having the same problem?
  16. SimoxTav
    Donut Sep 3, 2019
    SimoxTav , Sep 3, 2019 :
    So if i read correctly:
    You have an USB hub attached to the phone. That hub has:
    - a wireless dongle for mouse and keyboard on a USB (3.0 or 2.0 port?)
    - a HDMI cable connected to an external display
    And u have a 1080p output with both mouse and kb working. Is it correct?
  17. mannyprays116
    Cupcake Sep 3, 2019
    mannyprays116 , Sep 3, 2019 :
    why does my t mobile 7 pro get no network with this beta? any beta. my phone e gets locked and it asks to get unlocked And I have no network
  18. Pedronunorochasantos
    Cupcake Sep 3, 2019
  19. Shevach
    Froyo Sep 3, 2019
    Shevach , Sep 3, 2019 :
    first Google how to put the international ROM on your phone then if your sim unlocked you can install this if not at least update to the international so when it's normal release you will still get it over a month after then TMobile.
    Dbarnes0486 likes this.
  20. webnizam
    Froyo Sep 3, 2019
    webnizam , Sep 3, 2019 :
    wow, that's much impressive.
    downloading now, will update once i finish flashing.
