828
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo
    KitKat Sep 8, 2019
    Swejuggalo , Sep 8, 2019 :
    You mean that it resets over time or never works?
    H1509642441700 likes this.
  2. H1509642441700
    Cupcake Sep 8, 2019
    H1509642441700 , Sep 8, 2019 :
    it will reset and coming back to normal mode
  3. Swejuggalo
    KitKat Sep 8, 2019
    Ok. Known issue. It happens from time to time of some reason. Hopefully fixed in beta 2.
  4. H1509642441700
    Cupcake Sep 8, 2019
    H1509642441700
    it will reset and coming back to normal mode​
    and this option navigation gesture left n right back option not showing and working in user 2 profile too
  5. Swejuggalo
    KitKat Sep 8, 2019
    You could use the feedback tool that is built-in the community app to rapport that.
    I don't use more than one profile myself.
  6. Pa1KumarM
    Froyo Sep 8, 2019
    Pa1KumarM , Sep 8, 2019 :
    I've Installed OB1 in OnePlus 7 (Regular) Few days before...
    I haven't faced any issue for last few days...
    But today when I'm using Twitter suddenly black screen appeared with a pop up message saying Qualcomm dump crash .. and I tried switching Volume up and power button simultaneously for few seconds then my phone restarted ....
    Is anyone having this issue!????
  7. H1509642441700
    Cupcake Sep 8, 2019
    OKay
  8. Swejuggalo
    KitKat Sep 8, 2019
    Known issue. Many have gotten that. But never happened for me (7 Pro)
    Pa1KumarM likes this.
  9. mycatisajoker
    Gingerbread Sep 8, 2019
    mycatisajoker , Sep 8, 2019 :
    You don't have to read 4000 messages to find answers. If you just skim read like any ten pages, you will find the same questions over and over again. Even more amazing, if people actually read the initial message from Manu, they would find many questions answered there.
  10. H1509642441700
    Cupcake Sep 8, 2019
    OK will read
    H1561960043803 likes this.
  11. Alejandro R.
    Cupcake Sep 8, 2019
    Alejandro R. , Sep 8, 2019 :
    Hi,
    I recently installed the Open Beta for the 7 Pro and it's impossible to keep disabled the heads up notifications (that pop up of WhatsApp, Telegram, Twitter and this Forum notifications too) and keep enable the Horizon Light with notifications.
    When you disable it on the App (e.g. WhatsApp) or in the Android notificacions center, Horizon light didnr work, the remains off when the notifications was ringing.
    I've tried several combinations but nothing works.
    Any help?
    Thanks and sorry for my english mistakes.
  12. kanchansill12121
    Eclair Sep 8, 2019
  13. Swejuggalo
    KitKat Sep 8, 2019
    What apps? Upgraded with or without factory reset? Tried reinstalling the apps?
  14. kanchansill12121
    Eclair Sep 8, 2019
    kanchansill12121 , Sep 8, 2019 :
    application like BHIM,AXIS bank ,PAYTM
  15. docnok63
    Ice Cream Sandwich Sep 8, 2019
  16. Swejuggalo
    KitKat Sep 8, 2019
    Ah. Banking apps. Seen several rapports of banking apps not working.
    In most cases it can be that the apps fails on Android 10 devices and they need to fix it. You should contact the developers. You may also send in a bug rapport with the feedback tool to Oneplus
  17. docnok63
    docnok63 , Sep 8, 2019 :
    Originally posted by @iampun33t and @Nic2112 and modified by me, I guess this needs to be reposted every 45 minutes or so:
    1. This is OOS Open Beta 1. It is based on final Android 10 from Google.
    2. As the thread title says, this Open Beta is for OnePlus 7 and 7 Pro. Please do not ask for update information for OnePlus 3/3T/5/5T/6/6T.
    3. The Open Beta will not work on the 7 Pro 5G Model. T-Mobile customers will need their SIM unlocked or they won't have cellular data after installing OB1. If you just want to test it, WiFi will still work. Information on how to get your SIM unlocked can be found on the XDA forum.
    4. There is no release date for stable version. We are guessing 3-6 weeks.
    5. Installing Open Beta from stable will not wipe your data.
    6. As confirmed by @Baymax earlier in this thread, moving from Open Beta channel to stable WILL wipe your data.
    7. Again confirmed by @Baymax, once you are on the Open Beta, you will not get the Stable update, but you will continue to get Open Beta updates even after Stable is released.
    8. Stable 9.5.11 will not get an OTA for this build. If you're on T-Mobile firmware, you will not have a local update option. You will need to install international firmware first or use TWRP to install.
    9. The Oxygen Updater app has been updated to support the Open Beta and is now the preferred method to install OB1. Instructions on the proper settings to use to get the OB1 in the app are here.
    10. If you have already downloaded file and want to continue trying to use it, it needs to be in the root of the internal storage (moved from Download directory and at the top of internal sdcard and not in any folder)
    11. If your downloaded file has a .jar extension then rename it and remove the .jar part. The file needs to be in .zip extension to work. Do not unzip this file. If you are having installation problems, post a screenshot of current file location so we can help you.
    12. The rollback to Pie is a manual installation and the download links can be found in the first post of this thread. Steps 10 and 11 describe where the file should be and how it should be named in order for it to be found in local update. Once again, this WILL wipe your data. Have a backup ready.
    13. As this is an Open Beta, it has some known and unknown bugs. Some banking apps will not work. Be ready for it. The list of known bugs, features of OB1, and all instructions and download links are in the first post of this thread. You should read it as many times as you need to.
    14. If at any time you have Qualcomm Crash Dump mode, hold the power + volume up key for 10 seconds. Phone will reboot automatically and you'll be fine. This is a known OB1 bug which I believe related to a new multimedia parser OP is testing in OB1.
    15. People are experiencing excessive battery drain with OB1. This is a bug with Google Play Services (just look at its drainage in battery settings) and is happening with other phone models as well on Android 10. This needs to be fixed by Google and is not an OB1 bug.
    16. Feedback/bug reports in this thread are welcome, but also use the links at the bottom of the first post to ensure that OnePlus sees your input.
    Important notes:
    • There are 2 major models of the phones grouped in this forum, each with multiple variants. That is about a dozen possibility so a problem reported by one user might not apply to your specific model
    • When people report issues, they rarely specify if they are rooted or not and if they have customized their installs. When it comes to stability, there is a big difference between stock, and stock/rooted/bunch of Magisk modules installed. Customizing increases possibility of problems
    • Lastly, not everyone did a factory reset after the upgrade which is known to help
    So when you read about an issue, chances are the person reporting the issue has a different phone setup than you; the issue might not apply to you or you might have issues that others don't.
    More info about Open Beta Program from OnePlus Head of User Experience Design:
    https://forums.oneplus.com/threads/oxygenos-beta-program-explained.469761/
  18. 73ND41
  19. Swejuggalo
    KitKat Sep 8, 2019
  20. 73ND41
    73ND41 , Sep 8, 2019 :
    OnePlus 7 Pro (GM1913), was working until today.
