861
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. X1562616142536
    Cupcake Sep 8, 2019
    X1562616142536 , Sep 8, 2019 :
    Amazing One plus + ,but in this open beta there are some bugs ..
    like my WiFi goes off and on and the and even the data keeps play, and the finger print is too slow now compared to the last OS version
  2. DigiWise
    Cupcake Sep 8, 2019
    DigiWise , Sep 8, 2019 :
    I have to go up far more than 50% of the screen to be able to open the left menus or open something like chat on Instagram. This is very annoying even I am using both hands. I wish then the back gesture and other options are 50/50 not more.
  3. maazkazi1991
    Froyo Sep 8, 2019
    maazkazi1991 , Sep 8, 2019 :
    I feel the Bluetooth earphones output is a little low in the Beta update....anyone else felt the same?
  4. Swejuggalo
    Lollipop Sep 8, 2019
    Swejuggalo , Sep 8, 2019 :
    Have you moved it into root directory? Should look something like this. You may need to remove jar if the file is not named only zip.
    A alternative way to update.
    How to update to Open Beta with Oxygen Updater http://bit.ly/2HTDBRY
    romsi_rk likes this.
  5. C1563444973666
    Donut Sep 8, 2019
    C1563444973666 , Sep 8, 2019 :
    No please follow the procedure given above and the android 10 is awesome and very smooth
  6. C1563444973666
    Donut Sep 8, 2019
    One plus team great work done and the mobile is very smooth and is gliding , my best wishes and keep rocking
  7. Y1567845455785
    Cupcake Sep 8, 2019
  8. H3FTA
    Donut Sep 8, 2019
    H3FTA , Sep 8, 2019 :
    By 1+ 7P does that include the 5G model or am I left in the dark like every other update [e]1f440[/e]
  9. Swejuggalo
    It excludes 5G variant
  10. H3FTA
    Donut Sep 8, 2019
    No change there
  11. I1567808206260
    Cupcake Sep 8, 2019
    I1567808206260 , Sep 8, 2019 :
    I rolled back my os to android 9 from android 10 beta. Now my gesture to go back is swipe up from the bottom left or right at the edge, instead of swipe inwards from left or right edges. Is this unique to me or it's part of the new update? It has made my phone very difficult to use with gestures.
  12. docnok63
    Jelly Bean Sep 8, 2019
    docnok63 , Sep 8, 2019 :
    Sorry to hear that. You will have to reinstall. I had a broken Google Assistant on 2 out of 5 of my DP5 installs (I reverted to Pie quite a lot.)
    For the rest of these quoted questions:
    The OB1 community has put together a post to give detailed information on OB1 installation, rollback to Pie from OB1, and possible releases. Please read it here.
  13. docnok63
    This is the OnePlus method of gesture which many here like with gaming apps and whatnot. From the sides is the Google default method in Android 10. You got used to one type of gesturing, you can get used to another.
  14. Swejuggalo
    Left right to go back is a 10 beta thing.
    There are 3 methods available in gesture settings though.
  15. The_Rock90
  16. I1567808206260
    Cupcake Sep 8, 2019
    I had the chinese version of pie oxygen os before I tried 10 beta and the gestures were always swipe from left or right inwards since I bought my phone. I thought I rolled back with the wrong package but its fine. I will get used to it.
  17. BeingIncog
    Nougat Sep 8, 2019
  18. Bharath1106
    Eclair Sep 8, 2019
    Bharath1106 , Sep 8, 2019 :
    me tooo
  19. Swejuggalo
    Regular 7? Then no. It uses wide lens
  20. Swejuggalo
    Ok. It existed in Hydrogen too. But not Oxygen.
