836
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. Chris_Bonomi
    Eclair Sep 9, 2019
    G_Genesis_Kalolo_SZPa likes this.
  2. bandit1976
    Gingerbread Sep 9, 2019
    bandit1976 , Sep 9, 2019 :
    who knows... :rolleyes:
    This ist Oneplus 7 pro and Oneplus 7... :eek:
  3. G_Genesis_Kalolo_SZPa
    Cupcake Sep 9, 2019
    G_Genesis_Kalolo_SZPa , Sep 9, 2019 :
    when I click the link it takes me to a blank page; so I opened it in chrome and downloaded from there, but now it says file can't open. please help
  4. giaur500
    Jelly Bean Sep 9, 2019
    giaur500 , Sep 9, 2019 :
    When ready
    blackvoske likes this.
  5. martinklaus
    martinklaus , Sep 9, 2019 :
    Hobfully OnePlus will release next beta tomorrow.
  6. G_Prashant_Choudhary_jbp
    Cupcake Sep 9, 2019
  7. B1559018022647
    Cupcake Sep 9, 2019
    B1559018022647 , Sep 9, 2019 :
    The download package is inside a folder. So select it by pressing and select move option. Then paste it in phone memory, directly. Not inside any folder. Then go to update and select local upgrade.
  8. F_Ginny_Multani_jeNo
    Cupcake Sep 9, 2019
    F_Ginny_Multani_jeNo , Sep 9, 2019 :
    how i install can you have any video on YouTube how to install this beta version
  9. ngydat
    KitKat Sep 9, 2019
    ngydat , Sep 9, 2019 :
    Before rushing to the installation, do you know what a beta is ?
  10. FIROZ77
    Eclair Sep 9, 2019
    FIROZ77 , Sep 9, 2019 :
    Bluetooth is causing problem in car.
    the song was heard intermittently...
    my device is oneplus 7..
  11. ngydat
    KitKat Sep 9, 2019
    If you don't report bugs properly, don't expect the stable update to be better
  12. M1561818945590
    Donut Sep 9, 2019
    M1561818945590 , Sep 9, 2019 :
  13. M1561818945590
    Donut Sep 9, 2019
  14. A1558090359108
    Cupcake Sep 9, 2019
    A1558090359108 , Sep 9, 2019 :
    I downloaded the file copied it or storage and when I opened the local update it is showing this.
    what should I do??
  15. Sopheak_Noun
    Eclair Sep 9, 2019
    the_reckoner likes this.
  16. A1558090359108
    Cupcake Sep 9, 2019
  17. G_Harsh_Darji_kIHH
    Cupcake Sep 9, 2019
  18. DanielSun1981
    Cupcake Sep 9, 2019
    H1561960043803 likes this.
  19. BuLLeTyE
    Cupcake Sep 9, 2019
    BuLLeTyE , Sep 9, 2019 :
    Hey. I had the same problem with my bluetooth headphones. I was able to fix this by turning off battery optimisation for your music app (spotify in my case).
    Settings --> Battery --> Battery optimisation --> Select your music app --> Select "Don't optimise"
  20. Bruno Muguet
    Eclair Sep 9, 2019
    Bruno Muguet , Sep 9, 2019 :
    Is it on root folder? See if you are inserting inside downloads or any other folder. You don't need to extract the file also.
