875
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. Georgeoneplus7pro
    Jelly Bean Sep 9, 2019
    Georgeoneplus7pro , Sep 9, 2019 :
    We know and we don't want to tell you.
  2. pbr1111
    Donut Sep 9, 2019
    pbr1111 , Sep 9, 2019 :
    You will be not able to go back from beta to stable without wiping data. It has been like this since the open betas of OnePlus 3.
    H1561960043803 likes this.
  3. H1561960043803
    Ice Cream Sandwich Sep 9, 2019
    H1561960043803 , Sep 9, 2019 :
    Sam_Chinu
    Hi there, if I like to go back to pie from Android 10 beta version. Does my phone format or will it normally rollback without omitting my data.​
    from beta back to stable Android pie will wipe your data I believe.
    docnok63 likes this.
  4. shikaris
    Cupcake Sep 9, 2019
    shikaris , Sep 9, 2019 :
    Question: when the stable update gets released.... will the ones who have opted for the open beta get the stable update via OTA?
  5. Kaiken
    Donut Sep 9, 2019
    Kaiken , Sep 9, 2019 :
    Messages app by Google uses the Notification sound and vibration instead of the SMS ringtone and vibration.
  6. Marek_Orovnicky
    Honeycomb Sep 9, 2019
    Marek_Orovnicky , Sep 9, 2019 :
    shikaris
    Question: when the stable update gets released.... will the ones who have opted for the open beta get the stable update via OTA?​
    no, you will be getting only open beta updates via OTA, but you can flash stable build manually
  7. shikaris
    Cupcake Sep 9, 2019
    will flashing it manually to a stable build erase my data?
  8. Marek_Orovnicky
    most probably yes
  9. prfraczek
    prfraczek , Sep 9, 2019 :
    Previously when I copied text I have had google translator pop-up bubble so I could easily translate. Not anymore. Could you confirm this is not just my setup, please?
  10. Sibiarasu
    Donut Sep 9, 2019
  11. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 9, 2019
    Swejuggalo , Sep 9, 2019 :
    No. You need to manually install Stable yourself. If the beta does not allow a dirty flash to stable you even need to revert to Pie and wipe data.
  12. rahman_vb
    Cupcake Sep 9, 2019
  13. H1561960043803
  14. Swejuggalo
    Yes. Do a backup if you need to save some data
  15. idbl_fanatic1
    idbl_fanatic1 , Sep 9, 2019 :
    Read the directions on how to go back, remove the .ZIP from the end of the file
  16. H1561960043803
    crazy_designer_007
    i cant go back to oxygen os !what can i do now?
    why not? local update doesn't see the file? see the response above mine... he typed faster lol except remove . jar and leave the . zip
  17. Marek_Orovnicky
    why not? did you download downgrade build from the first post?
  18. rahman_vb
    Cupcake Sep 9, 2019
    rahman_vb , Sep 9, 2019 :
    yes but it doesn't work
  19. H1561960043803
    be more specific. how doesn't it work?
  20. Marek_Orovnicky
