796
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. H1560200324058
    Cupcake Sep 11, 2019
    H1560200324058 , Sep 11, 2019 :
    downloaded a different keyboard , but it comes dark and can't change the theme within the app, no way of overcoming this lol? I tried cache clear, restart, different themes on the phone, curious if not no worries I can use gboard
  2. wawanredblack
    Froyo Sep 11, 2019
  3. Borijess3
    Froyo Sep 11, 2019
    Borijess3 , Sep 11, 2019 :
    Should be out in the next few hours to compete with the iPhone 11 [e]1f601[/e]
    fcarmona likes this.
  4. john362
  5. G_Николай_Фед
    G_Николай_Фед , Sep 11, 2019 :
    Hey. I have an unexpected problem! I cannot connect AirPods to my Oneplus 7 Pro. I tried on several other Android phones, everything is fine. When I try to connect to OnePlus, nothing happens. The phone sees Airpods, but nothing happens. Within 1-2 minutes, the phone tries, the connection is trying, but then I see: the connection failed. I tried to restart the phone, airpods. Nothing helped. Please help!
  6. blackvoske
    Donut Sep 11, 2019
    bandit1976 likes this.
  7. apat26
    Froyo Sep 11, 2019
    docnok63 likes this.
  8. Georgeoneplus7pro
    Ice Cream Sandwich Sep 11, 2019
    Georgeoneplus7pro , Sep 11, 2019 :
    7T will make it KO and he will kill him on iPhone 11.
  9. docnok63
    docnok63 , Sep 11, 2019 :
    The OB1 community has put together a post to give detailed information on OB1 installation, rollback to Pie from OB1, bugs, and possible releases. Please read it here.
  10. bullione
  11. bandit1976
    Gingerbread Sep 11, 2019
    bandit1976 , Sep 11, 2019 :
    search the thread... :confused:
    but yes, you can...
  12. Bashar_Khroubi
    Bashar_Khroubi , Sep 11, 2019 :
    i want to get back to Android 9 but it says that if i do that it will reset my device to factory defaults , does that mean everything on my device will be deleted?
  13. docnok63
    Ask yourself. When you get the phone from the factory does it have anything that you put on it?
    OnePlusAim likes this.
  14. ddhbanger
    Honeycomb Sep 11, 2019
    ddhbanger , Sep 11, 2019 :
    Just a few posts up is the answer to your question.
    If you click on the link a fluffy unicorn appears and life is wonderful again.
  15. Bashar_Khroubi
    my quest was very clear , will everything on my device will be deleted if i go back to Android 9 or not?
  16. Nic2112
    Nic2112 , Sep 11, 2019 :
    Y E S
    Bashar_Khroubi likes this.
  17. avik331
    Froyo Sep 11, 2019
    avik331 , Sep 11, 2019 :
    yes it means that you will have a clean slate device, everything will be wiped off
  18. Bashar_Khroubi
    finally! thanks for help !
    avik331 likes this.
  19. Bashar_Khroubi
  20. Bashar_Khroubi
    after upgrading to Android 10 , cloning apps( from google play not from OnePlus system ) stopped working ,i just get a black screen when i use a cloned app , does anyone knows how to solve this ?
