844
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. AzuLa9713
    Honeycomb Sep 11, 2019
    AzuLa9713 , Sep 11, 2019 :
    was a joke man.
  2. kubavat09
    Eclair Sep 11, 2019
  3. JmcRepair33
  4. SameepAhden
    Donut Sep 11, 2019
  5. Nic2112
    Ice Cream Sandwich Sep 11, 2019
    Nic2112 , Sep 11, 2019 :
    There is an article on Android Police about it.
  6. swa100
    Gingerbread Sep 11, 2019
    swa100 , Sep 11, 2019 :
    About my bootloader? dude ... I said that I do not have unlocked my bootloader and still have low resolution Netflix on OB1.
  7. Sir_Pool_de_Float_MD
    Sir_Pool_de_Float_MD , Sep 11, 2019 :
    Most people won't install custom/beta ROMs with a locked bootloader.
    However, since in your case you did not do that, the other possible cause is being that this ROM is beta and will not be Google Play certified, Netflix may also restrict HD content to only certified devices.
  8. swa100
    it passes all tests , so it's certified. Seems that Netflix did not certify it on their end. same problem with the fact that all Android phones (if I'm correct) aren't certified for 1080p Netflix. 720p is Max for Android if I'm correct.
  9. Sir_Pool_de_Float_MD
    Does the Play Store show the device as Certified?
  10. swa100
  11. VjOnePlus85
    Cupcake Sep 11, 2019
  12. fcarmona
  13. venkygrandhi
  14. VjOnePlus85
  15. Slakyn
    Slakyn , Sep 11, 2019 :
    I used 1+7 6/128 with 9.5.8 MP, I can't go to OBT. It's show "System update failed", Please tell me why?
  16. Guptasachin760
    Froyo Sep 11, 2019
    Guptasachin760 , Sep 11, 2019 :
    in stable OS 9.5.8 and all other old version notification panel was not coming down during call.
    but was happy to see it was working perfectly in Oxygen OS open beta 1!!
    Hope to see it working on stable os android 10 also :)
  17. fcarmona
    fcarmona , Sep 11, 2019 :
    Yes.
    The first post says where to download, but, are you really sure to do the update?
    You must read a lot to do and fix all the issues.
  18. fcarmona
    double check about the file you downloaded and check the md5
  19. patrick.h.day
    Froyo Sep 11, 2019
    patrick.h.day , Sep 11, 2019 :
    To all the users crying and whining over issues with the Open Beta to Android 10.
    1: It's still beta, and things may/may not break, they'll eventually get fixed.
    2: If you don't know how to do something, SEARCH is your best friend.
    3: This forum is for the 7 series, not the 3/5/6. so stop spamming the boards crying about how your phone doesn't have it yet.
    4: Resources are finite, the same goes for the software devs. They most likely have a large percentage working on the latest platform first, that's how it works. When the 8 series comes out, the 7/7t will take a back seat to it, and so on.
    5: For T-Mobile users, this update breaks data, for the time being we most likely have to wait for the final release, unless OP decides were worthy of being included in the beta.
    Just chill, sit back, and have a beer, soda, tea, etc. We're lucky to have a company that interacts with it's users. It could be worse.....you could be running an LG or Sammy phone which won't get updated till next year at the earliest.
  20. R1565547067300
    Donut Sep 11, 2019
    R1565547067300 , Sep 11, 2019 :
    well said brother!! yeah imagine LG I made mistakes of buying their phones before they neeeeever update them
