874
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. patrick.h.day
    Froyo Sep 11, 2019
    patrick.h.day , Sep 11, 2019 :
    we'll get it, hopefully sooner rather than later. I had to roll back due to it breaking data, but I'm not mad. I would rather have a stable fast platform, rather than a rushed steaming pile of code.
  2. hector689
    Froyo Sep 11, 2019
    hector689 , Sep 11, 2019 :
    for people that have the T-Mobile varient there are people on the xda forums who work for TMobile who have offered to Sim unlock phones on their end, they require some info. did it for mines even though I was financing it through TMobile and I am now rocking the 10 beta.
  3. patrick.h.day
    Froyo Sep 11, 2019
    I have two OP 7's, and have my sister the one I had unlocked. I need to ask to have the same done to this.
  4. R1565547067300
    Donut Sep 11, 2019
    R1565547067300 , Sep 11, 2019 :
    same conclusion I came too
  5. nvansummeren
    Cupcake Sep 11, 2019
    nvansummeren , Sep 11, 2019 :
    Thank you, rebooting my device solved it indeed
    Nitin_Jangra likes this.
  6. hector689
    Froyo Sep 11, 2019
    yes I sent my info as a pm, and got the unlock request approved rather quick, keep in mind that you need to have the T-Mobile version of oxigen is installed in order to us the unlock app after it's been approved.
  7. R1565547067300
    Donut Sep 11, 2019
    yup I did that mine still won't work even though unlocked so rolled back and gonna wait it out
  8. hector689
    Froyo Sep 11, 2019
    R1565547067300 likes this.
  9. Nitin_Jangra
  10. K1568216729941
  11. Pradeep.tiwari
    Pradeep.tiwari , Sep 11, 2019 :
    I updated Android 10 open beta 1 and using last 7 days and observed there are some application compatibility issue
  12. sauvi
    Froyo Sep 11, 2019
    sauvi , Sep 11, 2019 :
    I have updated my One Plus 7 to open beta. Will i get stable Android 10 OTA once it's available or i need roll it back to Pi to get stable OTA?
  13. docnok63
    Jelly Bean Sep 11, 2019
    docnok63 , Sep 11, 2019 :
    You are not correct: https://help.netflix.com/en/node/23939
    It doesn't matter if they pass all tests or not if they're only one the basic plan. They need to be on the Standard plan or higher for 1080p.
    https://www.techradar.com/how-to/which-netflix-plan-is-for-you
    The OB1 community has put together a post to give detailed information on OB1 installation, rollback to Pie from OB1, bugs, and possible releases. Please read it here.
  14. zaktazzik
    zaktazzik , Sep 11, 2019 :
    Have any of you tried using the TMO unlock app? I'm only a couple months into financing, and I was able to permenantly network unlock my device, MSM to switch to international, and install beta. All works fine, phone on the network, and I am now able to treat my phone as if I bought it from Oneplus direct.
  15. zaktazzik
    Regarding those with TMO varient... Have any of you tried using the TMO unlock app before using MSM to switch to international? I'm only a couple months into financing, and I was able to permenantly network unlock my device, MSM to switch to international, and install beta. All works fine, phone on the network, and I am now able to treat my phone as if I bought it from Oneplus direct.
  16. Nic2112
    Ice Cream Sandwich Sep 11, 2019
  17. Nic2112
    Nic2112 , Sep 11, 2019 :
    Probably not, you'll get beta updates.
  18. swa100
    Gingerbread Sep 11, 2019
  19. dhopmans
    Honeycomb Sep 11, 2019
    dhopmans , Sep 11, 2019 :
    Read post 1 dude. Unbelievable.....
  20. docnok63
    JorgeMaTeixeira likes this.
