826
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. JmcRepair33
    Honeycomb Sep 11, 2019
    JmcRepair33 , Sep 11, 2019 :
    Correction, i have Tmobile phone converted it to international and unlocked and even before unlock the op1 worked perfect! VoLTE, All data APN settings and everything works perfectly, There is not difference in the hardware from international in Tmobile version homie other then the OS from tmobile and being locked. I unlocked t and switched to international then flashed op beta 1 and i can prove my box and reciept and they op beta 1 if you like in a screen shot
  2. JmcRepair33
    If you convert to international with the tool offered in XDA you can i have a Tmobile phone and unlocked it and swucthed to international. but i swtiched to international before it was unlocked and it stil worked fine so you DONT have to be unlocked, but to unlock it you must go back to Stock firmware from tmobile and unlock it via the Tmobile unlock app then switch and flash back international. But you dont have to Unlock it for any reason if you are going to stay in TMOBILE. I can prove it to you if you like. You can use the Xda Conversion Tmobile to International and international to tmobile reverse if you want to go back. I will show you the link how i did mine going to look for the link on how easy it is literaly. Here is the link to do it. make sure you give your computer time to install the Drivers if not switch your phone to fastboot a few times to your phoe is recognized by the computer and all the drivers install. Follow the directiosn and it works. did for me.
    https://www.xda-developers.com/t-mobile-oneplus-7-pro-international-firmware-install/
    thats the link
  3. R1565547067300
    Donut Sep 11, 2019
    R1565547067300 , Sep 11, 2019 :
    thanks man!!
    yeah I think my issue was I converted to international then unlocked for some reason mine won't pull data on ob1
  4. JmcRepair33
    just contact tmobile could be a sim card issue that its not working. one thing that usually works is go to where it says reset and back up in settings to reset your phone and reset the Network,bluetooth wireless settiungs and restart the phone and bam it should work it happened to me. if that doesnt work go to apn settings and reset to default the apn. if there is no apn then you need a new sim card. but you dont have to tell tmobile when you call them that you put different firmware. thay can still help you, i got them to send me another sim card for freee, and so then i called and told them to put a note and so i can pick it up at any authorize retailer and so i went to my local authorzed tmobile store doesnt have to be corporate and they will give you another sim card for free. this issue happened to me and all i did was had to reset those network settings and the reset of the phone menu, but i had another issue with my voicemails later not not related to firmware and they switched my sim card for free just in case if it is a sim card issue they wil give you a sim card for free if you ask for it
  5. NIKKI PVK
    Eclair Sep 11, 2019
    NIKKI PVK , Sep 11, 2019 :
    just now updated my mobile to Android 10 using beta version. after updating to 10. I noticed 2 duplicate apps found. I will attach the screenshot. please look into it. why can't we use only one like: FIKE MANAGER/ FILES/ GALLERY .
    ALL THESE 3 purpose is saving photos, documents, videos. why we have to use 3. instead of 1.
    OnePlus department please look into it
    sepehrss7 likes this.
  6. Matt 80
    Lollipop Sep 11, 2019
    Matt 80 , Sep 11, 2019 :
    All beta related issues/comments/questions should be posted in the dedicated beta thread.
  7. R1565547067300
    Donut Sep 11, 2019
  8. Elee0628
    Cupcake Sep 11, 2019
    Elee0628 , Sep 11, 2019 :
    Can confirm. Sim unlocked and flashed the 10 beta. Haven't ran into any issues.
    fcarmona likes this.
  9. NIKKI PVK
    Eclair Sep 11, 2019
    can you show me beta thread please once
  10. kaldpils
    Froyo Sep 11, 2019
    kaldpils , Sep 11, 2019 :
    in next beta release please give us Bluetooth controller support for as many controllers as possible.
    thanks in advanced..
  11. Cervantes
    Lollipop Moderator Sep 11, 2019
    Cervantes , Sep 11, 2019 :
    Hi
    the thread is up: sticky
    The beta or update thread is a thread of questions and/or commentary
    Please, You read the first post
    Thread merged
  12. sepehrss7
  13. sepehrss7
  14. J1558107392905
  15. vriesdejoop
    Ice Cream Sandwich Sep 11, 2019
    vriesdejoop , Sep 11, 2019 :
    through the feedback section read the OP
  16. D1552634625405
    D1552634625405 , Sep 11, 2019 :
    Tried this thing !
    first of all it is really great to use !
    but there are few bugs in it !
    the phone automatically plays songs ,
    video starts in background automatically !
    like i tried playing a video then left that video without watching !
    then cleared all the recent apps and then i heard a voice , then i noticed that voice is from that video ! its in the background !
    and sometimes camera icon is not working without password !
    we have to input password then it goes to the homescreen and then we can start tha camera !
    there are few bugs in the camera also or may be its in my handset!
    the Red Colour in RGB ratio is high and that picture becomes more of a Red Shade !
  17. JmcRepair33
    Great I'm happy if your happy questions just ask brother
  18. R3ix84
    Froyo Sep 11, 2019
    R3ix84 , Sep 11, 2019 :
    Yes this is the first beta, its normal. I already submitted to oneplus my issues too, ppl should realize this is a beta version and not conplaint about issues
    fcarmona and Loper_fan like this.
  19. Turbospeed440
  20. Nic2112
    Nic2112 , Sep 11, 2019 :
    That's the only beta
