875
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. crisjohn02
    Froyo Sep 4, 2019
    crisjohn02 , Sep 4, 2019 :
    No, I don't kid around. True dialer app is one of the most important app so as the messaging, settings, camera or the gallery app. What your complaining is not even a system app and why would op team bother to test google dialer app when they have their own dialer? Anyway glad you found the solution for your problem.
  2. oneplustwoindia
    Froyo Sep 4, 2019
  3. docnok63
    Jelly Bean Sep 4, 2019
    docnok63 , Sep 4, 2019 :
    You only have to disable your Magisk modules, not uninstall. After upgrade, you can re-enable.
    You're going to have to root your phone and flash the TMo firmware from TWRP.
    E1564718011740 likes this.
  4. BMG1900
    Gingerbread Sep 4, 2019
    BMG1900 , Sep 4, 2019 :
    How did you revert back to 9.5.11? tried several times, but the file doesn't show in local upgrade
  5. mcjinx216
    Cupcake Sep 4, 2019
    mcjinx216 , Sep 4, 2019 :
    thank you.
  6. docnok63
    I'm not sure because I always use TWRP, but I think the DPs and now Open Beta only see the downgrade file from the first post and will not see any normal Pie .zips. I hope you've checked that the file is a zip and not .zip.jar. If so, remove the .jar
    H1561960043803 likes this.
  7. 0xMatt
    Cupcake Sep 4, 2019
    0xMatt , Sep 4, 2019 :
    Please add the ability to remove games visible in gamespace to be hidden from the app overview.
  8. tekipr
    Eclair Sep 4, 2019
  9. Pankaj_Rai
  10. docnok63
    You already can. Longpress on the icon and select remove
  11. Gauravraushan1
    Cupcake Sep 4, 2019
    Gauravraushan1 , Sep 4, 2019 :
    i formet my phone to open beta and happy to say that guys go for it no any type of problem i have seen, and what a optimisations ,great work oneplus
  12. Ganther9448
    Eclair Sep 4, 2019
  13. xByt3z
    Eclair Sep 4, 2019
  14. 0xMatt
    Cupcake Sep 4, 2019
    um I'm not talking about the home screens.
  15. Pa1KumarM
    JoseReyes69 likes this.
  16. Sigmanp320x
  17. ESavage648
    Donut Sep 4, 2019
  18. Amit.Chaudhary
  19. OnePlusAim
    Honeycomb Sep 4, 2019
    OnePlusAim , Sep 4, 2019 :
    I haven't been able to get twrp onto the phone but bootloader is unlocked
  20. HirenThakor
    HirenThakor , Sep 4, 2019 :
    hahaha... Surprising
