875
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. shishupalk
    Froyo Sep 15, 2019
  2. DanTanCM
    Cupcake Sep 15, 2019
  3. docnok63
    Jelly Bean Sep 15, 2019
    docnok63 , Sep 15, 2019 :
    The OB1 community has put together a post to give detailed information on OB1 installation, rollback to Pie from OB1, bugs, and possible releases. Please read it here.
  4. VS.007
    VS.007 , Sep 15, 2019 :
    After updating the my OnePlus 7 to Android 10 Beta Ver. I'm not getting the option to enable or disable the notch display. Is it because of the Beta is designed for 7 Pro specially and as we know there is no notch in 7 Pro and developers didn't work on that yet? please suggest...
  5. Th3X30nShaun
    Donut Sep 15, 2019
    Th3X30nShaun , Sep 15, 2019 :
    that method requires root access I've always been on the beta for all of my OP devices this is the only one I've had a problem trying to update.
  6. Melkuse Daniel
    Ice Cream Sandwich Sep 15, 2019
    Melkuse Daniel , Sep 15, 2019 :
    Following the file name you should rename it as .zip, for instance if the file name is like OnePlus oxygen open beta 1 ota_170_1901300.rar then rename it's as .zip after the last character.
  7. dragidavid
    dragidavid , Sep 15, 2019 :
    oh it's a zip already. that's what I downloaded
  8. docnok63
    People here are asking about better camera performance here and Gcam settings\tweaks\fixes. I'm not much of a picture taker, so I don't really concentrate on this too much, but I did some research today on how to fix Gcam getting stuck on HDR+ processing and found this nice Magisk module. While it says it's only for the front camera, on our device, it works for both. I know, it requires root, sorry non-root users. It was posted in the Xiaomi Mi Note 3 forums but like most things Gcam, it works perfectly fine on my 7 Pro and I can't see why it wouldn't work on the 7 as well.
    https://forum.xda-developers.com/mi-note-3/themes/magisk-google-camera-hdr-portrait-mod-t3768961
    HDR+ processing is so fast with the Snapdragon 855 you might not think it's working, but just take a shot with HDR+ enabled vs HDR+ off in a semi-low light condition and you'll immediately notice the difference.
    I'm using it with Arnova's Gcam v6.3 and it works great!
    https://f.celsoazevedo.com/file/cfiles/gcm1/Gcam_6.3.020_Test_V3.0beta2.190816.1635.apk
  9. docnok63
    Known issue for OP7 users. I'm sure it will be addressed in a future, hopefully next, Open Beta.
    Sorry, the thread title tells you that this build is not designed for your device. You're right. To get this working on the 5G variant would take root access, a fair amount of time, and considerable risk as there's no MSMtool for the 5G variant either. If your device gets softbricked, there's no recovery from it. I have highly suggested multiple times in this thread that the 5G community start up a donation thread on XDA and buy a OP7/7Pro developer a 5G variant. I'd go with a combination kernel/ROM developer.
    Georgeoneplus7pro likes this.
  10. AzuLa9713
    Honeycomb Sep 15, 2019
  11. ASHISH K S
    Eclair Sep 15, 2019
    ASHISH K S , Sep 15, 2019 :
    colour of backgroud shoud be this kind of black as we can see notification easily,drak black colour should be replaced from everywhere
    docnok63 likes this.
  12. Tridonan
    Eclair Sep 15, 2019
    Tridonan , Sep 15, 2019 :
    after downloading the beta update, when OnePlus will finally roll out the official update for Android 10, will i be able to download the official update during that time??
  13. Covrivov
    Gingerbread Sep 15, 2019
  14. Roemer
    Roemer , Sep 15, 2019 :
    Really enjoying the beta. Installing was a breeze. I have a question though, is there any way to get the android pie navigation back? The one with the slidy thing instead of three buttons? I got really used to it and it's incredibly annoying to use the three button navigation now... (I don't like the gestures at all). I am rooted so a magisk package would work for me as well.
    Any help is appreciated!
  15. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 15, 2019
    Swejuggalo , Sep 15, 2019 :
    Doing nothing will get you future beta updates that will continue to come even after stable arrives.
    Unless a dirty flash with full update is possible over the beta (without issues and loss of data) its possible that a wipe is needed either by doing a downgrade or that the update itself from beta to stable does a wipe for you.
  16. Swejuggalo
    I guess you are referring to that some call 2 button navigation. Think I saw some adb command solution somewhere here...
  17. Roemer
    Yess that's what I meant. Any chance you could find it..?
  18. Swejuggalo
  19. charmingash
    charmingash , Sep 15, 2019 :
    when i open pubg mobile my phone screen gone blank nothing working its not even working you are saying about lag
  20. Roemer
    Thank you so much!! [e]1f64f[/e]
