875
Oxygen OS Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. H1561960043803
    Ice Cream Sandwich Sep 15, 2019
    H1561960043803 , Sep 15, 2019 :
    shubham0307
    can you share the link​
    really ? you can't find page 1 ? this is page 343 . click that little square with the 343 on it and scroll back to page one and you'll find your answer
    docnok63 and Georgeoneplus7pro like this.
  2. Shubh0307
    Donut Sep 15, 2019
    H1561960043803 likes this.
  3. MarKush420
    Cupcake Sep 15, 2019
    MarKush420 , Sep 15, 2019 :
    A couple of days ago i updated to the android 10 Beta, and now my phone wont rotate. (yes, automatic rotation is on)
    When i downloaded the downgrading update (downdate?) I realized that the file was .jar, and not .zip like the Beta file was.
    Both files are currently in the "root directory" but the downgrade (.jar) file isnt showing up in the local upgrade menu.
    What do i do now?
  4. H1561960043803
    Georgeoneplus7pro likes this.
  5. Shubh0307
    Donut Sep 15, 2019
  6. Nic2112
  7. mikkado
    Gingerbread Sep 15, 2019
    mikkado , Sep 15, 2019 :
    [QUOTE = "MarKush420, post: 20755192, member: 2334949"] Il y a quelques jours, j'ai mis à jour l'Android 10 Beta et mon téléphone ne tourne plus. (oui, la rotation automatique est activée)
    Quand j'ai téléchargé la mise à jour (downdate?), J'ai réalisé que le fichier était .jar, et non pas .zip comme le fichier bêta.
    Les deux fichiers se trouvent actuellement dans le "répertoire racine", mais le fichier de rétrogradation (.jar) ne figure pas dans le menu de mise à niveau local.
    Qu'est-ce que je fais maintenant? [/ QUOTE]
    Delete ".jar"
    the latest file letters must be ".zip"
  8. H1561960043803
  9. raju023
  10. sureshgknd
  11. H1561960043803
    delete . jar from the end so it ends in zip
  12. Shubh0307
    Donut Sep 15, 2019
    Shubh0307 , Sep 15, 2019 :
    and then i will b having normal phone... and will revive updates as and when oneplus gives it
  13. sureshgknd
    sureshgknd , Sep 15, 2019 :
    how can I do first file of beta I have delated
    now I was downloaded back file it is not in zip formate
  14. H1561960043803
    ummmm ... what format is it in? does it have . jar at the end, and what phone do you have?
  15. mikkado
  16. sureshgknd
    I'm using 7 pro
    file formate is zip.jar
    I have file like zip but not showing in update
  17. H1561960043803
    is it out of your download folder and in the root directory of your phone?. local update should see it then.
  18. sureshgknd
  19. H1561960043803
    rename the file delete the . jar at the end of the file so it ends in . zip
  20. Shubh0307
    Donut Sep 15, 2019
    i just downdraged my phn
    but i lost all my data
    which was on phone
    it became all new
    how do i recover the lost data ?
    some 100gb+ dats
